跳转到主内容
Brentwood TS-292B Bread Grabber Spring Replacement
你所需要的
  1. Brentwood TS-292B Bread Grabber Spring Replacement, Bread Grabber Spring: 步骤 1 中的图像 1,2 Brentwood TS-292B Bread Grabber Spring Replacement, Bread Grabber Spring: 步骤 1 中的图像 2,2
    • Turn the toaster upside down.
    • Remove the five 6 mm screws with a Phillips #2 screwdriver.
  2. Brentwood TS-292B Bread Grabber Spring Replacement: 步骤 2 中的图像 1,2 Brentwood TS-292B Bread Grabber Spring Replacement: 步骤 2 中的图像 2,2
    • Grasp the plastic pull lever cover firmly and pull to remove it. This may require force.
    • Lift the cover upwards to remove it.
    • When removing the cover, do not damage the cable connector bundle that attaches the cover to the toaster.
  3. Brentwood TS-292B Bread Grabber Spring Replacement: 步骤 3 中的图像 1,1
    • To detach the bundled cable connector, carefully pull it away from the circuit board.
  4. Brentwood TS-292B Bread Grabber Spring Replacement: 步骤 4 中的图像 1,2 Brentwood TS-292B Bread Grabber Spring Replacement: 步骤 4 中的图像 2,2
    • Pull the toaster lever down.
    • While holding the toaster lever down, use the spudger to pull the metal tabs away from the wired bread grabber.
    • Continuing to hold the toaster lever down, pinch the wires inward and pull up to carefully remove them from the toaster.
结论
0条评论
添加评论
浏览统计数据:
过去 24 小时: 2
过去 7 天: 3
过去 30 天: 14
总计 388
