跳转到主内容
本篇指南是分解流程而非维修指南。 如果您要维修您的bread maker,应参考我们的维修指南
  1. Bread Maker Teardown, Bread Maker teardown: 步骤 1 中的图像 1,1
    • The Toast Select Luxe adjusts the toasting time for each type of bread. 'Lift & Look' to check if it's done. Press 'A Bit More' and to give it just that… a little bit more. Follow toasting progress with the LED countdown indicator. Crafted with brushed stainless steel in premium metallic finishes and chrome accents.
    • VARIABLE BROWNING CONTROL Toast to your ideal browness level while the LED indicates your browning progress.
    • INNOVATIVE AUTO FEATURES 1-Touch 'A Bit More' and 'Lift & Look' functions are derived directly from your feedback and makes for flawless toasting.
    • EASY CLEANING No need to ever lift when cleaning. Just pull out the front crumb tray and tip it into the dustbin.
    • Construction Materials:Brushed stainless steel body with back-lit buttons.
    • Dimensions (WxDxH):8.2" x 7.9" x 13.4"
    • Power:1000 Watts Voltage:120Volts, 60Hz Settings:6 Bread Settings: Wholewheat, White, Bagel, Waffles, Pastries and English Muffins 4 Functions: 'Lift & Look', 'A Bit More'/Reheat, Frozen and Cancel
  2. Bread Maker Teardown, Remove the screws: 步骤 2 中的图像 1,2 Bread Maker Teardown, Remove the screws: 步骤 2 中的图像 2,2
    • From the bottom, the bread maker has 4 screws securing two pieces of the shell.
    • Time to cut it open!First thing’s first, let’s turn over the machine, there are 4 screw in sight, therefore a screw driver is up.
    • Take a closer look after removing the screws on the bottom, we can see there are still 4 plastic pads and silicon circles that are waiting to be taken away.
  3. Bread Maker Teardown: 步骤 3 中的图像 1,2 Bread Maker Teardown: 步骤 3 中的图像 2,2
    • You might notice that the shells are not apart yet, but take a closer look, it’s already loose.
    • This is when you flip it upside-down again, find the very botton on the side and take it off, a simple twist and pull will do the work.
  4. Bread Maker Teardown: 步骤 4 中的图像 1,3 Bread Maker Teardown: 步骤 4 中的图像 2,3 Bread Maker Teardown: 步骤 4 中的图像 3,3
    • Time to get our first glimpse inside this bread maker.
    • To take off the mainboard, you need a screw driver to remove those three screws.
    • Unplug those wires highlighted in the photo.
    • Ta-da! You successfully removed the mainboard!
  5. Bread Maker Teardown: 步骤 5 中的图像 1,3 Bread Maker Teardown: 步骤 5 中的图像 2,3 Bread Maker Teardown: 步骤 5 中的图像 3,3
    • To teardown the mainboard from the other side, this is what you have to do--
    • Unplug all wires connected to it.
    • picture 2 shows how it should be like after you did the instruction above.
    • All you have to do now, is to take away the mainboard along with the metal chip beneath it.
  6. Bread Maker Teardown: 步骤 6 中的图像 1,1
    • This is the last step of taking the shell apart--cut the wire.
  7. Bread Maker Teardown, dismiss the disk: 步骤 7 中的图像 1,3 Bread Maker Teardown, dismiss the disk: 步骤 7 中的图像 2,3 Bread Maker Teardown, dismiss the disk: 步骤 7 中的图像 3,3
    • First, take off the screws like shown in the picture.
    • Then you will see a board also secured with screws——repeat your last move.
    • There you have a small board!
  8. Bread Maker Teardown: 步骤 8 中的图像 1,2 Bread Maker Teardown: 步骤 8 中的图像 2,2
    • Same spot, same move—— remove three screws on top of the disc.
    • Then there you are—— a small disc!
  9. Bread Maker Teardown: 步骤 9 中的图像 1,2 Bread Maker Teardown: 步骤 9 中的图像 2,2
    • Let's move on to the inside of the shell, shall we?
    • There are so many screws on this thing, huh? Let's just screw them off and take out the small board.
  10. Bread Maker Teardown: 步骤 10 中的图像 1,2 Bread Maker Teardown: 步骤 10 中的图像 2,2
    • Same old same old. Screw them off and take out the transparent plastic lid.
  11. Bread Maker Teardown: 步骤 11 中的图像 1,2 Bread Maker Teardown: 步骤 11 中的图像 2,2
    • bend the metal sheets shown in the picture.
    • Then you will have those small components.
  12. Bread Maker Teardown: 步骤 12 中的图像 1,2 Bread Maker Teardown: 步骤 12 中的图像 2,2
    • Unbend the sheet metal in p1&2.
  13. Bread Maker Teardown: 步骤 13 中的图像 1,3 Bread Maker Teardown: 步骤 13 中的图像 2,3 Bread Maker Teardown: 步骤 13 中的图像 3,3
    • Next, take off the clips in p1&2.
    • Generated by all the steps above, you can pull out this metal wire easily.
  14. Bread Maker Teardown: 步骤 14 中的图像 1,1
    • However, the last step is a lot more difficult, this is to seperate its silver machine case with its black plastic base.
    • This step requires specialised tool, for any other normally seen screw drivers/tools will easily bend the metal inside.
    • Therefore, if not necessary, don't teardown this part without specialised tools.
  15. Bread Maker Teardown: 步骤 15 中的图像 1,1
    • All components of a bread maker.
Diana S
于04/24/20注册
241 声望
撰写一个指南
1指南评论
Je ne sais pas de quelle origine vient l'appellation "Machine à pain" pour cet appareil, mais en France on appelle cela un grille-pain. L'appellation "Machine à pain" est destinée à un appareil qui permet de pétrir et cuire le pain ce qui est franchement différent.
Gilles Guérin - 回复
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 8
过去 30 天: 26
总计 543
