跳转到主内容
Braven BRV-HD Speakers Replacement
你所需要的
  1. Braven BRV-HD Speakers Replacement, Battery: 步骤 1 中的图像 1,2 Braven BRV-HD Speakers Replacement, Battery: 步骤 1 中的图像 2,2
    • Placing the device on its back with the BRV-HD logo facing up, remove the eight 5mm hexagon 2.0 screws on the front panel.
    • Make sure the device is turned off before starting.
  2. Braven BRV-HD Speakers Replacement: 步骤 2 中的图像 1,1
    • Lift the front panel off of the speaker using a plastic opening tool.
  3. Braven BRV-HD Speakers Replacement: 步骤 3 中的图像 1,2 Braven BRV-HD Speakers Replacement: 步骤 3 中的图像 2,2
    • Placing the device with the back panel facing up, remove the eight 5mm hexagon 2.0 screws from the back panel.
  4. Braven BRV-HD Speakers Replacement: 步骤 4 中的图像 1,1
    • Lift the back panel off of the device with a plastic opening tool.
  5. Braven BRV-HD Speakers Replacement: 步骤 5 中的图像 1,2 Braven BRV-HD Speakers Replacement: 步骤 5 中的图像 2,2
    • Turning the device on its side, unscrew the four 15mm hexagon 2.0 screws on the charging port panel.
  6. Braven BRV-HD Speakers Replacement: 步骤 6 中的图像 1,1
    • Remove the outer rubber flap and the plastic side port panel.
  7. Braven BRV-HD Speakers Replacement: 步骤 7 中的图像 1,2 Braven BRV-HD Speakers Replacement: 步骤 7 中的图像 2,2
    • Place the device on its front.
    • Loosen the four 12mm Phillips screws in the four corners with a J1 screwdriver.
    • Loosen the two 8mm Phillips screws in the center with a J1 screwdriver.
    • These screws are difficult to reach and will require a screwdriver extension piece.
  8. Braven BRV-HD Speakers Replacement: 步骤 8 中的图像 1,1
    • Pull off the rubber sleeve surrounding the speaker using your hands.
    • There is adhesive binding the sleeve to the speaker and force will be required to remove the sleeve.
  9. Braven BRV-HD Speakers Replacement: 步骤 9 中的图像 1,1
    • Lift the black covering off of the speaker using both hands.
    • Loose screws that you were unable to remove with the screwdriver will be removed when you lift off the black covering.
  10. Braven BRV-HD Speakers Replacement: 步骤 10 中的图像 1,1
    • Remove the four 12mm Phillips screws securing the two battery brackets with a J1 screwdriver.
    • Move any wires aside to have better access to the screws securing the battery.
  11. Braven BRV-HD Speakers Replacement: 步骤 11 中的图像 1,1
    • Remove the two brackets that hold down the battery using your hands.
  12. Braven BRV-HD Speakers Replacement: 步骤 12 中的图像 1,2 Braven BRV-HD Speakers Replacement: 步骤 12 中的图像 2,2
    • Use the plastic opening tool to lift up the battery.
    • Remove the battery using your hands.
    • The wires connecting the battery to the motherboard are still plugged in. Avoid pulling on the battery or these wires may break.
  13. Braven BRV-HD Speakers Replacement: 步骤 13 中的图像 1,1
    在这个步骤中使用的工具:
    购买
    • Disconnect the wire attaching the battery to the motherboard.
    • There is green glue on the wire ports preventing the wires from falling out. Peel and remove this glue as necessary.
    • Be careful when pulling out the wires from their ports. The metal stems attached to the ports can break. A spudger or tweezers may help.
  14. Braven BRV-HD Speakers Replacement, Speakers: 步骤 14 中的图像 1,2 Braven BRV-HD Speakers Replacement, Speakers: 步骤 14 中的图像 2,2
    • Locate the two wires that connect the right speaker to the motherboard.
    • Gently disconnect the wires from the motherboard.
  15. Braven BRV-HD Speakers Replacement: 步骤 15 中的图像 1,2 Braven BRV-HD Speakers Replacement: 步骤 15 中的图像 2,2
    • Locate the two wires that connect the left speaker to the motherboard.
  16. Braven BRV-HD Speakers Replacement: 步骤 16 中的图像 1,2 Braven BRV-HD Speakers Replacement: 步骤 16 中的图像 2,2
    • Position the device facing up and remove eight 10mm Phillips head screws using a J1 Phillips head screwdriver.
  17. Braven BRV-HD Speakers Replacement: 步骤 17 中的图像 1,3 Braven BRV-HD Speakers Replacement: 步骤 17 中的图像 2,3 Braven BRV-HD Speakers Replacement: 步骤 17 中的图像 3,3
    • Lift the speaker out using the metal spudger and complete lifting by using your hands.
    • Remove the speakers with your hands and replace with new ones.
结论
2等其他人完成本指南。
Matthew Nguyen
于09/15/16注册
297 声望
创作了2篇指南
团队
CSU Fullerton, Team 1-5, Bruce Fall 2016 CSU Fullerton, Team 1-5, Bruce Fall 2016 的会员
CSUF-BRUCE-F16S1G5
5 名成员
创作了5篇指南
3条评论
Where can I find a replacement speaker?
dillon0987 - 回复
Peerless by Tymphany PLS-65F25AL01-02
Alex -
Where can I find or order a replacement speaker for BRV PRO
jvp_hunter28 - 回复
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 2
过去 30 天: 16
总计 1,707
