跳转到主内容
Braven BRV-HD Motherboard Replacement
你所需要的
  1. Braven BRV-HD Motherboard Replacement, Battery: 步骤 1 中的图像 1,2 Braven BRV-HD Motherboard Replacement, Battery: 步骤 1 中的图像 2,2
    • Placing the device on its back with the BRV-HD logo facing up, remove the eight 5mm hexagon 2.0 screws on the front panel.
    • Make sure the device is turned off before starting.
  2. Braven BRV-HD Motherboard Replacement: 步骤 2 中的图像 1,1
    • Lift the front panel off of the speaker using a plastic opening tool.
  3. Braven BRV-HD Motherboard Replacement: 步骤 3 中的图像 1,2 Braven BRV-HD Motherboard Replacement: 步骤 3 中的图像 2,2
    • Placing the device with the back panel facing up, remove the eight 5mm hexagon 2.0 screws from the back panel.
  4. Braven BRV-HD Motherboard Replacement: 步骤 4 中的图像 1,1
    • Lift the back panel off of the device with a plastic opening tool.
  5. Braven BRV-HD Motherboard Replacement: 步骤 5 中的图像 1,2 Braven BRV-HD Motherboard Replacement: 步骤 5 中的图像 2,2
    • Turning the device on its side, unscrew the four 15mm hexagon 2.0 screws on the charging port panel.
  6. Braven BRV-HD Motherboard Replacement: 步骤 6 中的图像 1,1
    • Remove the outer rubber flap and the plastic side port panel.
  7. Braven BRV-HD Motherboard Replacement: 步骤 7 中的图像 1,2 Braven BRV-HD Motherboard Replacement: 步骤 7 中的图像 2,2
    • Place the device on its front.
    • Loosen the four 12mm Phillips screws in the four corners with a J1 screwdriver.
    • Loosen the two 8mm Phillips screws in the center with a J1 screwdriver.
    • These screws are difficult to reach and will require a screwdriver extension piece.
  8. Braven BRV-HD Motherboard Replacement: 步骤 8 中的图像 1,1
    • Pull off the rubber sleeve surrounding the speaker using your hands.
    • There is adhesive binding the sleeve to the speaker and force will be required to remove the sleeve.
  9. Braven BRV-HD Motherboard Replacement: 步骤 9 中的图像 1,1
    • Lift the black covering off of the speaker using both hands.
    • Loose screws that you were unable to remove with the screwdriver will be removed when you lift off the black covering.
  10. Braven BRV-HD Motherboard Replacement: 步骤 10 中的图像 1,1
    • Remove the four 12mm Phillips screws securing the two battery brackets with a J1 screwdriver.
    • Move any wires aside to have better access to the screws securing the battery.
  11. Braven BRV-HD Motherboard Replacement: 步骤 11 中的图像 1,1
    • Remove the two brackets that hold down the battery using your hands.
  12. Braven BRV-HD Motherboard Replacement: 步骤 12 中的图像 1,2 Braven BRV-HD Motherboard Replacement: 步骤 12 中的图像 2,2
    • Use the plastic opening tool to lift up the battery.
    • Remove the battery using your hands.
    • The wires connecting the battery to the motherboard are still plugged in. Avoid pulling on the battery or these wires may break.
  13. Braven BRV-HD Motherboard Replacement: 步骤 13 中的图像 1,1
    在这个步骤中使用的工具:
    购买
    • Disconnect the wire attaching the battery to the motherboard.
    • There is green glue on the wire ports preventing the wires from falling out. Peel and remove this glue as necessary.
    • Be careful when pulling out the wires from their ports. The metal stems attached to the ports can break. A spudger or tweezers may help.
  14. Braven BRV-HD Motherboard Replacement, Motherboard: 步骤 14 中的图像 1,3 Braven BRV-HD Motherboard Replacement, Motherboard: 步骤 14 中的图像 2,3 Braven BRV-HD Motherboard Replacement, Motherboard: 步骤 14 中的图像 3,3
    • Locating the two screws on either side of the motherboard, unscrew the two 8 mm Phillips head screws using a J1 Phillips head screw driver.
  15. Braven BRV-HD Motherboard Replacement: 步骤 15 中的图像 1,3 Braven BRV-HD Motherboard Replacement: 步骤 15 中的图像 2,3 Braven BRV-HD Motherboard Replacement: 步骤 15 中的图像 3,3
    • Slide out the motherboard using your hands.
    • Unplug all the wires attaching the motherboard to the device.
    • Remove and replace motherboard.
    • Some wires are glued to the motherboard with a green glue. Remove the glue before removing the wires.
结论
另外一个人完成了本指南。
团队
CSU Fullerton, Team 1-5, Bruce Fall 2016 CSU Fullerton, Team 1-5, Bruce Fall 2016 的会员
CSUF-BRUCE-F16S1G5
5 名成员
创作了5篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 7
总计 910
