跳转到主内容
Braven BRV-1M Outer Casing Replacement
你所需要的
  1. Braven BRV-1M Outer Casing Replacement, Outer Casing: 步骤 1 中的图像 1,1
    • To remove the outer casing, use a 3mm Hex bit to remove the 4 large 12mm Hex screws on both sides of the device.
  2. Braven BRV-1M Outer Casing Replacement: 步骤 2 中的图像 1,1
    • Using the Metal Spudger, carefully pry each side of the rubber casing away from the device.
    • A little resistance should be felt, but not enough to bend the spudger.
  3. Braven BRV-1M Outer Casing Replacement: 步骤 3 中的图像 1,1
    • To remove the inner plastic casing, use a Phillips #00 head bit to remove the 16 small 9mm screws surrounding the top side of the device.
  4. Braven BRV-1M Outer Casing Replacement: 步骤 4 中的图像 1,1
    • Carefully lift away the housing and replace the broken casing/component. Replace using the new casing.
结论
另外一个人完成了本指南。
Erik Oliva
于02/14/18注册
607 声望
创作了6篇指南
团队
USF Tampa, Team S2-G1, Eyestone Spring 2018 USF Tampa, Team S2-G1, Eyestone Spring 2018 的会员
USFT-EYESTONE-S18S2G1
4 名成员
创作了6篇指南
一条评论
Where can I buy parts for this speaker? My rear charging door has broken off disabling the ruggedness. Be easier to buy versus build new piece.
Michael Harruff - 回复
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 10
总计 635
