跳转到主内容
Braven BRV-1M Motherboard Replacement
你所需要的
  1. Braven BRV-1M Motherboard Replacement, Outer Casing: 步骤 1 中的图像 1,1
    • To remove the outer casing, use a 3mm Hex bit to remove the 4 large 12mm Hex screws on both sides of the device.
  2. Braven BRV-1M Motherboard Replacement: 步骤 2 中的图像 1,1
    • Using the Metal Spudger, carefully pry each side of the rubber casing away from the device.
    • A little resistance should be felt, but not enough to bend the spudger.
  3. Braven BRV-1M Motherboard Replacement: 步骤 3 中的图像 1,1
    • To remove the inner plastic casing, use a Phillips #00 head bit to remove the 16 small 9mm screws surrounding the top side of the device.
  4. Braven BRV-1M Motherboard Replacement: 步骤 4 中的图像 1,1
    • Carefully lift away the housing and replace the broken casing/component. Replace using the new casing.
  5. Braven BRV-1M Motherboard Replacement, Motherboard: 步骤 5 中的图像 1,1
    • To remove the motherboard, proceed to unscrew the 3 Phillips #00 bit type, 13mm long screws located on both sides of the motherboard.
  6. Braven BRV-1M Motherboard Replacement: 步骤 6 中的图像 1,1
    • Then, proceed to unscrew the 5 Phillips #00 bit type, 9mm long screws located on the face of the charging dock.
  7. Braven BRV-1M Motherboard Replacement: 步骤 7 中的图像 1,1
    • Disconnect the two 4-pin auxiliary button register cables connected on both sides of the motherboard.
  8. Braven BRV-1M Motherboard Replacement: 步骤 8 中的图像 1,1
    • Once disconnected, carefully remove the motherboard by pulling upwards.
结论
Erik Oliva
于02/14/18注册
607 声望
创作了6篇指南
团队
USF Tampa, Team S2-G1, Eyestone Spring 2018 USF Tampa, Team S2-G1, Eyestone Spring 2018 的会员
USFT-EYESTONE-S18S2G1
4 名成员
创作了6篇指南
一条评论
i need to eletric scheme!
anonymous 5979 - 回复
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 12
总计 254
