简介
The circuit board is a vital component to the function of the Braun Series 7 790cc-7 charging base. Many consumers may discard the charging base if it malfunctions rather than replace the circuit board. This can be expensive but by replacing the circuit board the razor can be used for an extended period of time. With the use of this Replacement Guide, one can easily change the circuit board in the charging base when it is required.
配件
无需配件。
  1. Remove the cleaner cartridge from the charging base.
    • Remove the cleaner cartridge from the charging base.
  2. Depress the 4 tabs while lightly pulling the cover from the base. Next, depress the 2 molded tabs while still pulling the cover from the base. Next, depress the 2 molded tabs while still pulling the cover from the base.
    • Depress the 4 tabs while lightly pulling the cover from the base.
    • Next, depress the 2 molded tabs while still pulling the cover from the base.
  3. Press inward on the side charging port while pulling cover from the base to separate.
    • Press inward on the side charging port while pulling cover from the base to separate.
  4. 所有超过US$100或包含 Pro Tech工具包的订单免费送货!
    浏览我们的商店
  5. Remove side charging port by prying tabs outward and rotating port upward. Remove side charging port by prying tabs outward and rotating port upward.
    • Remove side charging port by prying tabs outward and rotating port upward.
  6. Remove charging terminals by inserting a spudger from bottom the and sliding terminals up. Remove charging terminals by inserting a spudger from bottom the and sliding terminals up.
    • Remove charging terminals by inserting a spudger from bottom the and sliding terminals up.
  7. Remove solder from circuit board and remove charging harness. Remove solder from circuit board and remove charging harness.
    • Remove solder from circuit board and remove charging harness.
  8. Remove solder from wire harness leading to the charging base motor. Remove solder from wire harness leading to the charging base motor.
    • Remove solder from wire harness leading to the charging base motor.
  9. Use spudger to release tab at the top left of the circuit board. After the tab has been released the circuit board can be removed.
    • Use spudger to release tab at the top left of the circuit board.
    • After the tab has been released the circuit board can be removed.
结论
另外一个人完成了本指南。
Ian Hayes
于2017年11月07日注册
80 信誉积分
创作了2篇指南
团队
IUPUI, Team S3-G6, Harley Fall 2017 IUPUI, Team S3-G6, Harley Fall 2017 的会员
IUPUI-HARLEY-F17S3G6
3 名成员
创作了3篇指南
添加评论
浏览统计数据:
过去的24小时: 2
过去的7天: 12
过去的30天: 75
总计 460
