跳转到主内容
Braun Series 7 790cc-7 Battery Replacement
你所需要的
  1. Braun Series 7 790cc-7 Battery Replacement, Battery: 步骤 1 中的图像 1,2 Braun Series 7 790cc-7 Battery Replacement, Battery: 步骤 1 中的图像 2,2
    • Use a spudger to remove the rubber piece on the back of the razor.
  2. Braun Series 7 790cc-7 Battery Replacement: 步骤 2 中的图像 1,1
    • Use a Torx T8 to remove (4) 10 mm screws from housing.
  3. Braun Series 7 790cc-7 Battery Replacement: 步骤 3 中的图像 1,2 Braun Series 7 790cc-7 Battery Replacement: 步骤 3 中的图像 2,2
    • Remove the rear cover from the device.
  4. Braun Series 7 790cc-7 Battery Replacement: 步骤 4 中的图像 1,1
    • Remove the battery from the holster inside the device.
  5. Braun Series 7 790cc-7 Battery Replacement: 步骤 5 中的图像 1,1
    • Replace the battery with a new 1300 mAh Sanyo (UR18500Y) battery.
    • Be sure to insert the battery the correct way.
结论
27等其他人完成本指南。
Alex Speer
于11/07/17注册
763 声望
撰写一个指南
团队
IUPUI, Team S3-G6, Harley Fall 2017 IUPUI, Team S3-G6, Harley Fall 2017 的会员
IUPUI-HARLEY-F17S3G6
3 名成员
创作了5篇指南
27条评论
Any idea on how to remove/replace the drive unit? I bought a new one but the plastic backing is extremely hard to get off.
Chris - 回复
Thank you for the awesome tutorial Alex!
I just wanted to comment that a small flat-head screw driver can be used to remove the 4 screws (under the rubber handle piece) if you don’t have a Torx tool. The screws each have 1 small slot across the head and if you’re careful you can remove and re-install them without too much trouble.
Thanks again for helping to save me a lot of trouble with this Alex… and avoid having to buy a new electric razor!
-jb-
arcticassault - 回复
How do you reset the battery life indicator on the shaver after replacement?
jclemis - 回复
添加评论
浏览统计数据:
过去 24 小时: 28
过去 7 天: 177
过去 30 天: 822
总计 53,253
