跳转到主内容
Braun KMM1 Coffe Grinder Disassembly for cleaning
你所需要的
  1. Braun KMM1 Coffe Grinder Disassembly for cleaning, Braun KMM1 Coffe Grinder Disassembly for cleaning: 步骤 1 中的图像 1,1
    • First, remove the coffee powder container
  2. Braun KMM1 Coffe Grinder Disassembly for cleaning: 步骤 2 中的图像 1,1
    • Remove the cap of the bean container
  3. Braun KMM1 Coffe Grinder Disassembly for cleaning: 步骤 3 中的图像 1,2 Braun KMM1 Coffe Grinder Disassembly for cleaning: 步骤 3 中的图像 2,2
    • Now it's time to rotate the bean container anti-clockwise to remove it from the machine
    Hallo, habe gerad ein Exemplar bei Kleinanzeigen ergattert, allerdings kann ich den oberen Teil gar nicht drehen. Weder um den mahlgrad einzustellen, noch um das Ding abzunehmen. Gibt es einen Trick oder liegt es vielleicht am Schmutz? Freue mich über Anregungen
    Tina Keller - 回复
  4. Braun KMM1 Coffe Grinder Disassembly for cleaning: 步骤 4 中的图像 1,1
    • Here you can see the mill wheel which is now ready to be cleaned
    How do I disassemble this grinder?
    halka319 - 回复
    It is difficult to rotate anti-clockwise to dismantle. Please suggest some easy method to unscrew the top from the body. Thanks
    Nagarajan - 回复
  5. Braun KMM1 Coffe Grinder Disassembly for cleaning: 步骤 5 中的图像 1,3 Braun KMM1 Coffe Grinder Disassembly for cleaning: 步骤 5 中的图像 2,3 Braun KMM1 Coffe Grinder Disassembly for cleaning: 步骤 5 中的图像 3,3
    • Back to the bean container!
    • After a short cleaning action you should be able to loosen this three Philips screws
  6. Braun KMM1 Coffe Grinder Disassembly for cleaning: 步骤 6 中的图像 1,2 Braun KMM1 Coffe Grinder Disassembly for cleaning: 步骤 6 中的图像 2,2
    • Now the bean container is completely disassembled and ready for some cleaning work!
结论
16等其他人完成本指南。
Daniel
于07/06/15注册
895 声望
创作了2篇指南
团队
iFixit EU Team iFixit EU Team 的会员
Community
53 名成员
创作了1,000篇指南
9条评论
Hi Daniel,
Thanks for the tutorial.
Would you have, by any chance, the usermanual of the grinder?
I’m wondering to what grinding size the numbering is corresponding to.
Many thanks! :)
Best regards,
Greg
freestyle_on_the_moon - 回复
I have this same issue! Did you ever find out? Im guessing that the grind size of the KMM1 is the same as the KMM20? So left (where it says mocca)for finest grind, right for the largest grind?
Will Clempson -
Umm.. My bottom burr doesn’t seem to have screws and look like rivits. maybe previous owner stripped the screws :(
Zarni Ko - 回复
Mine has something like rivets as well. I used toothpicks and cotton swabs to clean as much as I could,, then had some luck running dried couscous through the grinder. Softer than rice and seemed to pick up the last bits of residue.
Zeke Kossover -
Gilt diese Anleitung zur Reinigung auch für die Braun Kaffeemühle 4045?
Karl-Heinz Kaufmann - 回复
Könnte sein. Das Gerät heißt KMM 20 Typ 4045, vermutlich eine Weiterentwicklung der KMM 1.
VauWeh -
My grinder is stuck on course how to I “clean it” recalibrate it?
Thanks
bonnienewman - 回复
Hi Daniel,
do you know by chance what size the burrs are? I was wodnering if I could upgrade my Braun with new and modern Burrs that maybe create less fines
Best
vizzzo - 回复
添加评论
浏览统计数据:
过去 24 小时: 11
过去 7 天: 32
过去 30 天: 143
总计 9,547
