跳转到主内容
Braun Aromaster KF440 one-way valve Replacement
你所需要的
  1. Braun Aromaster KF440 one-way valve Replacement, Access the base: 步骤 1 中的图像 1,1
    • Remove the carafe (coffee pot) from the coffee maker.
    • Turn the Braun Aromaster KF 440 upside down so the base is exposed.
  2. Braun Aromaster KF440 one-way valve Replacement, Remove the nut: 步骤 2 中的图像 1,1
    • Locate the nut at the center of the base and unscrew it with a pair of basic pliers.
  3. Braun Aromaster KF440 one-way valve Replacement, Remove the cover: 步骤 3 中的图像 1,1
    • Gently lift the cover away from the bottom of the coffee maker and remove it.
  4. Braun Aromaster KF440 one-way valve Replacement, Locate internal one-way valve: 步骤 4 中的图像 1,1
    • Locate the one-way valve.
  5. Braun Aromaster KF440 one-way valve Replacement, Pull out valve: 步骤 5 中的图像 1,1
    • Lift up on the one way valve to snap it out of place. (This shouldn't require much force).
  6. Braun Aromaster KF440 one-way valve Replacement, Push tube off the one-way valve: 步骤 6 中的图像 1,1
    • Using the larger plastic opening tool, gently push the tubing off of the one-way valve. (If the tubing is being stubborn and won't come off, run the metal spudger around the inside of tubing to free it up.)
  7. Braun Aromaster KF440 one-way valve Replacement, Lift valve: 步骤 7 中的图像 1,1
    • Completely remove one-way valve from the inside of the coffee maker.
结论
3等其他人完成本指南。
Dennis
于10/20/14注册
315 声望
创作了2篇指南
团队
Baylor, Team 8-12, Williams Fall 2014 Baylor, Team 8-12, Williams Fall 2014 的会员
BU-WILLIAMS-F14S8G12
3 名成员
创作了10篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 17
过去 30 天: 46
总计 3,337
