跳转到主内容
Braun Aromaster KF440 Internal Tubing Replacement Guide
你所需要的
  1. Braun Aromaster KF440 Internal Tubing Replacement Guide, Access the base: 步骤 1 中的图像 1,1
    • Remove the carafe (coffee pot) from the coffee maker.
    • Turn the Braun Aromaster KF 440 upside down so the base is exposed.
  2. Braun Aromaster KF440 Internal Tubing Replacement Guide, Remove the nut: 步骤 2 中的图像 1,1
    • Locate the nut at the center of the base and unscrew it with a pair of basic pliers.
  3. Braun Aromaster KF440 Internal Tubing Replacement Guide, Remove the cover: 步骤 3 中的图像 1,1
    • Gently lift the cover away from the bottom of the coffee maker and remove it.
  4. Braun Aromaster KF440 Internal Tubing Replacement Guide, Remove first tubing from one-way valve: 步骤 4 中的图像 1,1
    • Using the larger plastic opening tool, gently push the tubing off of the one-way valve located in the center. (If the tubing is being stubborn and won't come off, run the metal spudger around the inside of tubing to free it up.)
    • The piece will remain attached to the center plate for now.
  5. Braun Aromaster KF440 Internal Tubing Replacement Guide, Remove second tubing from hose: 步骤 5 中的图像 1,1
    • Using the larger plastic opening tool, gently push the tubing off of the valve located on the side. (If the tubing is being stubborn and won't come off, run the Spudger tool around the inside of tubing to free it up.)
  6. Braun Aromaster KF440 Internal Tubing Replacement Guide, Remove tubing from center plate: 步骤 6 中的图像 1,1
    • Using the larger plastic opening tool, gently push the tubing off of the center plate. (If the tubing is being stubborn and won't come off, run the metal spudger around the inside of tubing to free it up.)
  7. Braun Aromaster KF440 Internal Tubing Replacement Guide, Remove filter basket housing: 步骤 7 中的图像 1,1
    • Grab the filter basket housing firmly.
    • Lift upwards on the filter basket housing. You may need to use one hand to hold the body of the coffee maker in place in order to remove the piece.
  8. Braun Aromaster KF440 Internal Tubing Replacement Guide, Locate latches: 步骤 8 中的图像 1,1
    • Locate the two plastic latches on the inside of the coffee maker.
  9. Braun Aromaster KF440 Internal Tubing Replacement Guide, Remove the top: 步骤 9 中的图像 1,3 Braun Aromaster KF440 Internal Tubing Replacement Guide, Remove the top: 步骤 9 中的图像 2,3 Braun Aromaster KF440 Internal Tubing Replacement Guide, Remove the top: 步骤 9 中的图像 3,3
    • Wedge the plastic opening tool between the back of the coffee maker and its top.
    • Once the top is loose remove by lifting up on the top of the coffee maker.
  10. Braun Aromaster KF440 Internal Tubing Replacement Guide, Remove tube from the lid: 步骤 10 中的图像 1,3 Braun Aromaster KF440 Internal Tubing Replacement Guide, Remove tube from the lid: 步骤 10 中的图像 2,3 Braun Aromaster KF440 Internal Tubing Replacement Guide, Remove tube from the lid: 步骤 10 中的图像 3,3
    • Once the top is removed you will notice that there is a tube attached.
    • Remove the tube from the lid by using the opening tool.
    • Place the opening tool under the clasp and gently lift the plastic clasps.
  11. Braun Aromaster KF440 Internal Tubing Replacement Guide, Detach tube: 步骤 11 中的图像 1,1
    • Finally, firmly hold the tube. Wiggle the black component away from the tube by hand.
  12. Braun Aromaster KF440 Internal Tubing Replacement Guide, Tubes are ready for replacement: 步骤 12 中的图像 1,1
    • You now have your tubes removed and ready to be replaced.
结论
Darcy Groom
于10/19/14注册
343 声望
创作了3篇指南
团队
Baylor, Team 8-12, Williams Fall 2014 Baylor, Team 8-12, Williams Fall 2014 的会员
BU-WILLIAMS-F14S8G12
3 名成员
创作了10篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 16
过去 30 天: 73
总计 3,387
