简介
Removing the filter basket may be necessary if the filter basket is broken or clogged.
你所需要的
Grab the ridge on the left side of the coffee maker.
Rotate the filter basket to the right.
Grab the filter basket firmly and lift upwards. You may need to use one hand to hold the body of the coffee maker in place in order to remove the piece.
Wedge the plastic opening tool between the filter basket and its housing.
Be sure to wedge the tools close to the tab on the right side of the housing.
Wiggle tools to loosen the housing from the filter basket.
Once the filter basket has been pried loose, grab the filter basket and lift it out of the housing.
2条评论
How do you replace the pin in between the coffee carafe and water basket??
Put the upper hinge first, slide it in and lower to put the back one in. Check this video if in doubt: https://www.youtube.com/watch?v=FP5dKQqD...
