跳转到主内容
Braun Aromaster KF440 Filter Basket Replacement Guide
你所需要的
  1. Braun Aromaster KF440 Filter Basket Replacement Guide, Remove the carafe.: 步骤 1 中的图像 1,1
    • Remove the carafe from the coffee maker.
    • Set the carafe aside.
  2. Braun Aromaster KF440 Filter Basket Replacement Guide, Open the filter basket.: 步骤 2 中的图像 1,1
    • Grab the ridge on the left side of the coffee maker.
    • Rotate the filter basket to the right.
  3. Braun Aromaster KF440 Filter Basket Replacement Guide, Remove the filter basket housing.: 步骤 3 中的图像 1,1
    • Grab the filter basket firmly and lift upwards. You may need to use one hand to hold the body of the coffee maker in place in order to remove the piece.
  4. Braun Aromaster KF440 Filter Basket Replacement Guide, Loosen the filter basket from its housing.: 步骤 4 中的图像 1,1
    • Wedge the plastic opening tool between the filter basket and its housing.
    • Be sure to wedge the tools close to the tab on the right side of the housing.
    • Wiggle tools to loosen the housing from the filter basket.
  5. Braun Aromaster KF440 Filter Basket Replacement Guide, Remove the filter basket from its housing.: 步骤 5 中的图像 1,1
    • Once the filter basket has been pried loose, grab the filter basket and lift it out of the housing.
结论
Darcy Groom
于10/19/14注册
343 声望
创作了3篇指南
团队
Baylor, Team 8-12, Williams Fall 2014 Baylor, Team 8-12, Williams Fall 2014 的会员
BU-WILLIAMS-F14S8G12
3 名成员
创作了10篇指南
2条评论
How do you replace the pin in between the coffee carafe and water basket??
janfinochio - 回复
Put the upper hinge first, slide it in and lower to put the back one in. Check this video if in doubt: https://www.youtube.com/watch?v=FP5dKQqD...
Andrés Boza Arce -
添加评论
浏览统计数据:
过去 24 小时: 3
过去 7 天: 19
过去 30 天: 52
总计 5,780
