跳转到主内容
Bowers and Wilkins T7 Motherboard Replacement
你所需要的
  1. Bowers and Wilkins T7 Motherboard Replacement, Access Panel: 步骤 1 中的图像 1,1
    • As with all electronic devices, make sure your device is powered off before you begin.
    • Gently lift up the access panel; it should easily "pop" open.
  2. Bowers and Wilkins T7 Motherboard Replacement: 步骤 2 中的图像 1,1
    • Remove 14mm screws on the front panel with a J1 Phillips head screwdriver.
    • There are 8 screws in total.
  3. Bowers and Wilkins T7 Motherboard Replacement: 步骤 3 中的图像 1,2 Bowers and Wilkins T7 Motherboard Replacement: 步骤 3 中的图像 2,2
    • Be gentle, the rubber seal is fragile and easy to tear, resulting in cosmetic damage to your device.
    • Using the ifixit Opening Tool, carefully pry off the rubber seal around the sides.
    • The seal is held by adhesive, if this is proving difficult you can use a heat gun to help the process.
  4. Bowers and Wilkins T7 Motherboard Replacement: 步骤 4 中的图像 1,2 Bowers and Wilkins T7 Motherboard Replacement: 步骤 4 中的图像 2,2
    • The cover is the most difficult part to remove. As you work, pry continuously, moving the tool around the device, working it a little further as you go.
    • Using the ifixit Opening Tool, pry open at the seam found under the rubber seal.
    • As the cover starts to come off, you can lift up using your hand.
  5. Bowers and Wilkins T7 Motherboard Replacement: 步骤 5 中的图像 1,3 Bowers and Wilkins T7 Motherboard Replacement: 步骤 5 中的图像 2,3 Bowers and Wilkins T7 Motherboard Replacement: 步骤 5 中的图像 3,3
    在这个步骤中使用的工具:
    购买
    • Gently squeeze the internal locking mechanism inside the red and white terminals with either your fingers or a pair of precision tweezers.
    • While squeezing the internal locking mechanism, pull back the terminal.
    • Repeat this process for the second speaker.
  6. Bowers and Wilkins T7 Motherboard Replacement, Motherboard: 步骤 6 中的图像 1,3 Bowers and Wilkins T7 Motherboard Replacement, Motherboard: 步骤 6 中的图像 2,3 Bowers and Wilkins T7 Motherboard Replacement, Motherboard: 步骤 6 中的图像 3,3
    • Remove the leftmost 14mm screw with the J1 screwdriver tip.
    • Remove the rightmost 14mm screw with the J1 screwdriver tip.
    • With the screws removed, the motherboard is now loose.
  7. Bowers and Wilkins T7 Motherboard Replacement: 步骤 7 中的图像 1,3 Bowers and Wilkins T7 Motherboard Replacement: 步骤 7 中的图像 2,3 Bowers and Wilkins T7 Motherboard Replacement: 步骤 7 中的图像 3,3
    • Ensure you position your fingers, or a screwdriver tool with the 0.8 tip, in a position on the outside of the black tab.
    • It is advisable to use a nylon spudger to accomplish this task, because using a metal screwdriver like the one used in the image, can be unnecessarily dangerous around delicate connectors and the motherboard in general.
    • When working with electronics, it's important to choose a tool that's ESD-safe to avoid accidental damage.
    • Slide the black tab out so the cable is able to be removed.
    • At this point, the cable is removed.
    • These ports are difficult, as you need to simultaneously push the black tab while pulling the cable.
  8. Bowers and Wilkins T7 Motherboard Replacement: 步骤 8 中的图像 1,1
    • Pull out the cable that is attached to a port under the motherboard.
  9. Bowers and Wilkins T7 Motherboard Replacement: 步骤 9 中的图像 1,2 Bowers and Wilkins T7 Motherboard Replacement: 步骤 9 中的图像 2,2
    • Use the 0.8 and 1.0 screwdriver tips to press on the pins to release this cable.
    • The cable should slide out when the releases are pressed.
    • This cable can be difficult, as you need to simultaneously push the pins as you pull out the cable.
  10. Bowers and Wilkins T7 Motherboard Replacement: 步骤 10 中的图像 1,2 Bowers and Wilkins T7 Motherboard Replacement: 步骤 10 中的图像 2,2
    • Use the 0.8 screwdriver tip to press in the tabs keeping this cable in place.
    • The cable should easily slide out.
  11. Bowers and Wilkins T7 Motherboard Replacement: 步骤 11 中的图像 1,2 Bowers and Wilkins T7 Motherboard Replacement: 步骤 11 中的图像 2,2
    • Rotated the motherboard to access this cable.
    • Use your fingers to pull out the cable.
  12. Bowers and Wilkins T7 Motherboard Replacement: 步骤 12 中的图像 1,2 Bowers and Wilkins T7 Motherboard Replacement: 步骤 12 中的图像 2,2
    • The battery cable needs to be removed.
    • Use your fingers to pull the cable out of the port.
  13. Bowers and Wilkins T7 Motherboard Replacement: 步骤 13 中的图像 1,2 Bowers and Wilkins T7 Motherboard Replacement: 步骤 13 中的图像 2,2
    • The red cable has a tab to press in order to release the cable.
    • Slide out the cable while continuing to press and hold the tab.
  14. Bowers and Wilkins T7 Motherboard Replacement: 步骤 14 中的图像 1,2 Bowers and Wilkins T7 Motherboard Replacement: 步骤 14 中的图像 2,2
    • Rotate the motherboard to access the last cable.
    • Pull on the gold connector to disconnect the cable.
结论
Adam Kosianowski
于03/09/17注册
101 声望
撰写一个指南
团队
USF Tampa, Team S7-G1, Cagle Spring 2017 USF Tampa, Team S7-G1, Cagle Spring 2017 的会员
USFT-CAGLE-S17S7G1
5 名成员
创作了4篇指南
一条评论
OK, so now the motherboard is out. What can that acomplish? Where can you get a replacement? and where is there a circuit diagram to fault find??
james scanlon - 回复
添加评论
浏览统计数据:
过去 24 小时: 2
过去 7 天: 5
过去 30 天: 13
总计 850
