跳转到主内容
Bowers and Wilkins T7 Access Panel Replacement
你所需要的
  1. Bowers and Wilkins T7 Access Panel Replacement, Access Panel: 步骤 1 中的图像 1,1
    • As with all electronic devices, make sure your device is powered off before you begin.
    • Gently lift up the access panel; it should easily "pop" open.
  2. Bowers and Wilkins T7 Access Panel Replacement: 步骤 2 中的图像 1,1
    • Remove 14mm screws on the front panel with a J1 Phillips head screwdriver.
    • There are 8 screws in total.
  3. Bowers and Wilkins T7 Access Panel Replacement: 步骤 3 中的图像 1,2 Bowers and Wilkins T7 Access Panel Replacement: 步骤 3 中的图像 2,2
    • Be gentle, the rubber seal is fragile and easy to tear, resulting in cosmetic damage to your device.
    • Using the ifixit Opening Tool, carefully pry off the rubber seal around the sides.
    • The seal is held by adhesive, if this is proving difficult you can use a heat gun to help the process.
  4. Bowers and Wilkins T7 Access Panel Replacement: 步骤 4 中的图像 1,2 Bowers and Wilkins T7 Access Panel Replacement: 步骤 4 中的图像 2,2
    • The cover is the most difficult part to remove. As you work, pry continuously, moving the tool around the device, working it a little further as you go.
    • Using the ifixit Opening Tool, pry open at the seam found under the rubber seal.
    • As the cover starts to come off, you can lift up using your hand.
  5. Bowers and Wilkins T7 Access Panel Replacement: 步骤 5 中的图像 1,3 Bowers and Wilkins T7 Access Panel Replacement: 步骤 5 中的图像 2,3 Bowers and Wilkins T7 Access Panel Replacement: 步骤 5 中的图像 3,3
    在这个步骤中使用的工具:
    购买
    • Gently squeeze the internal locking mechanism inside the red and white terminals with either your fingers or a pair of precision tweezers.
    • While squeezing the internal locking mechanism, pull back the terminal.
    • Repeat this process for the second speaker.
结论
2等其他人完成本指南。
团队
USF Tampa, Team S7-G1, Cagle Spring 2017 USF Tampa, Team S7-G1, Cagle Spring 2017 的会员
USFT-CAGLE-S17S7G1
5 名成员
创作了4篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 4
过去 30 天: 34
总计 2,692
