跳转到主内容
加入维修社区 - 创建账户
Bottom Board Removal
你所需要的
  1. Bottom Board Removal, Engage Wired Optical Mouse Top and Outer Shell Removal: 步骤 1 中的图像 1,1
    • Flip the mouse over and peel off the stickers on the perimeter of the bottom of the mouse.
  2. Bottom Board Removal: 步骤 2 中的图像 1,1
    • Use the Phillips #1 screwdriver to remove four 5 mm screws from the bottom of the mouse.
    • Use the Phillips #1 screwdriver to remove the two 9 mm screws from the bottom of the mouse.
  3. Bottom Board Removal: 步骤 3 中的图像 1,3 Bottom Board Removal: 步骤 3 中的图像 2,3 Bottom Board Removal: 步骤 3 中的图像 3,3
    • Grab the top shell of the mouse and lift up to remove.
  4. Bottom Board Removal: 步骤 4 中的图像 1,1
    • The capacitors on this board can release stored electrical energy if touched.
    • Touch your capacitor discharge tool to the capacitor leads on the board to release the stored energy. If leads are inaccessible, wait until you've removed the board from the mouse body.
  5. Bottom Board Removal: 步骤 5 中的图像 1,2 Bottom Board Removal: 步骤 5 中的图像 2,2
    • Use a spudger to pry underneath the white plug and pop it out to disconnect the upper board from the lower board.
  6. Bottom Board Removal, Side Panels: 步骤 6 中的图像 1,2 Bottom Board Removal, Side Panels: 步骤 6 中的图像 2,2
    • Locate the 5 mm silver flat head mounting screws (2) to the left and right of the scroll wheel and remove with the Phillips #1 screwdriver.
  7. Bottom Board Removal: 步骤 7 中的图像 1,2 Bottom Board Removal: 步骤 7 中的图像 2,2
    • Locate the snaps on the bottom corners of the mouse side panels and pop the indicated snaps out, using a spudger or your fingernail.
  8. Bottom Board Removal: 步骤 8 中的图像 1,3 Bottom Board Removal: 步骤 8 中的图像 2,3 Bottom Board Removal: 步骤 8 中的图像 3,3
    • Repeat Step 6 for the opposite side panel in order to detach both sides from the base of the mouse.
  9. Bottom Board Removal: 步骤 9 中的图像 1,2 Bottom Board Removal: 步骤 9 中的图像 2,2
    • Grab the sides of the mouse and lift them up to detach from the base of the mouse.
  10. Bottom Board Removal, Bottom Board: 步骤 10 中的图像 1,2 Bottom Board Removal, Bottom Board: 步骤 10 中的图像 2,2
    • Pop the scroll wheel out of the snap holding it in place. You can use your finger or a spudger to do so.
  11. Bottom Board Removal: 步骤 11 中的图像 1,2 Bottom Board Removal: 步骤 11 中的图像 2,2
    • Locate the four 5 mm black flat head screws on the corners of the bottom board.
    • Unscrew these four black screws.
  12. Bottom Board Removal: 步骤 12 中的图像 1,3 Bottom Board Removal: 步骤 12 中的图像 2,3 Bottom Board Removal: 步骤 12 中的图像 3,3
    • Lift the bottom board up to remove from its mounting posts. This will separate it completely from the bottom panel of the mouse.
结论
4等其他人完成本指南。
royceeklund
于01/18/13注册
115 声望
创作了3篇指南
团队
Cal Poly, Team 18-36, Regan Winter 2013 Cal Poly, Team 18-36, Regan Winter 2013 的会员
CPSU-REGAN-W13S18G36
3 名成员
创作了30篇指南
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 7
过去 30 天: 34
总计 5,869
