跳转到主内容
Boss RC-1 Loop Station-Pedal Battery Replacement
你所需要的
  1. Boss RC-1 Loop Station-Pedal Battery Replacement, Battery: 步骤 1 中的图像 1,1
    • Push down on the pedal in order to relieve pressure on the thumbscrew.
  2. Boss RC-1 Loop Station-Pedal Battery Replacement: 步骤 2 中的图像 1,1
    • Remove the thumb screw at the bottom of the device.
    • Loosening the thumb screw far enough will also allow the pedal to open.
  3. Boss RC-1 Loop Station-Pedal Battery Replacement: 步骤 3 中的图像 1,2 Boss RC-1 Loop Station-Pedal Battery Replacement: 步骤 3 中的图像 2,2
    • Using the Phillips #0 screwdriver, remove the two screws that secure the pedal to the device.
  4. Boss RC-1 Loop Station-Pedal Battery Replacement: 步骤 4 中的图像 1,1
    • Take the battery out of the device.
  5. Boss RC-1 Loop Station-Pedal Battery Replacement: 步骤 5 中的图像 1,1
    • Disconnect the snap chord from the battery.
  6. Boss RC-1 Loop Station-Pedal Battery Replacement: 步骤 6 中的图像 1,1
    • Reassemble the device in the opposite order.
    • When tightening the thumbscrew back in the device, apply force to the pedal first (Do step 1 before step 2).
结论
To check if the batter replacement was successful, plug in a guitar cable into the “Output A” jack. If the red light turns on below the “check” (top of the device), then the looper pedal is working.
另外一个人完成了本指南。
0条评论
添加评论
浏览统计数据:
过去 24 小时: 2
过去 7 天: 17
过去 30 天: 73
总计 6,413
