跳转到主内容
Bose-301 Series II Tweeter Replacement
你所需要的
  1. Bose-301 Series II Tweeter Replacement, Tweeter: 步骤 1 中的图像 1,3 Bose-301 Series II Tweeter Replacement, Tweeter: 步骤 1 中的图像 2,3 Bose-301 Series II Tweeter Replacement, Tweeter: 步骤 1 中的图像 3,3
    • Begin the repair by placing the Bose-301 speaker vertically.
    • Using two hands, pull the speaker grill towards you and away from the speaker body.
  2. Bose-301 Series II Tweeter Replacement: 步骤 2 中的图像 1,1
    • Pull the main speaker grill towards you to remove it from the body structure.
  3. Bose-301 Series II Tweeter Replacement: 步骤 3 中的图像 1,3 Bose-301 Series II Tweeter Replacement: 步骤 3 中的图像 2,3 Bose-301 Series II Tweeter Replacement: 步骤 3 中的图像 3,3
    • Lay the speaker body on its back.
    • Using the Philips Screwdriver, carefully remove the four #2x19mm screws that mount the main speaker to the speaker body.
  4. Bose-301 Series II Tweeter Replacement: 步骤 4 中的图像 1,2 Bose-301 Series II Tweeter Replacement: 步骤 4 中的图像 2,2
    • Untwist the slack in the wires that are connected to the main speaker.
  5. Bose-301 Series II Tweeter Replacement: 步骤 5 中的图像 1,3 Bose-301 Series II Tweeter Replacement: 步骤 5 中的图像 2,3 Bose-301 Series II Tweeter Replacement: 步骤 5 中的图像 3,3
    • Carefully place the speaker off to the side.
    • Be sure to not place the speaker face down or put pressure on the speaker cone as this can damage the cone.
    • Be aware of the very strong magnet in the driver of the speaker, which can cause damage to electronic devices in close proximity.
    • Then untwist the slack in the wires that are connected to the tweeters.
  6. Bose-301 Series II Tweeter Replacement: 步骤 6 中的图像 1,1
    • Using the socket wrench and the 1/4" socket, unscrew the 12.5 mm bolt that mounts the tweeter to the bracket.
  7. Bose-301 Series II Tweeter Replacement: 步骤 7 中的图像 1,1
    • While holding the tweeter, use your other hand to feed the wire through the hole at the bottom of the tweeter mount.
  8. Bose-301 Series II Tweeter Replacement: 步骤 8 中的图像 1,2 Bose-301 Series II Tweeter Replacement: 步骤 8 中的图像 2,2
    • Remove the tweeter from the mount and locate the two wires that connect it to the speaker.
    • Using the pliers, untwist the wires that are attached to the two small rods at the bottom of the tweeter.
    • Repeat process for the second tweeter.
    • Be sure not to excessively bend the bare wires in order to reuse it for the replacement tweeters.
结论
To reassemble your speaker, follow these instructions in reverse order.
3等其他人完成本指南。
Patrick Emery
于01/09/17注册
174 声望
撰写一个指南
团队
USF Tampa, Team 15-3, Remmell Spring 2017 USF Tampa, Team 15-3, Remmell Spring 2017 的会员
USFT-REMMELL-S17S15G3
4 名成员
创作了1篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 4
过去 7 天: 21
过去 30 天: 67
总计 7,169
