跳转到主内容
Bose portable speaker battery Replacement
你所需要的
    • flip speaker over onto its back
    • using a heat gun, soften the adhesive holding the ring in place.
    • peel off the ring that covers the screws
    • using your screwdriver, undo the 4 screws that hold the base onto the body of the speaker.
    • using your heat gun, apply a slight amount of heat to soften the adhesive.
    • during reassembly, apply the new adhesive.
    • using your screwdriver, undo the 4 screws holding the speaker assembly in place.
    • carefully pry in the edge of the speaker assembly.
    • be very careful when prying as it is still connected to the motherboard wires.
    • using a spludger, carefully disconnect the speaker cables from the motherboard.
    • be very careful not to damage the connector.
    • using your spludger, carefully pry up the battery.
    • be very careful not to puncture the battery.
    • using 2 fingers, pinch the connector connecting the battery and pull it straight out.
结论
776831
于06/10/21注册
1,085 声望
创作了8篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 2
过去 30 天: 26
总计 303
