跳转到主内容
Bose Wave Radio AWR1-1W Speaker Replacement
你所需要的
  1. Bose Wave Radio AWR1-1W Speaker Replacement, Base: 步骤 1 中的图像 1,2 Bose Wave Radio AWR1-1W Speaker Replacement, Base: 步骤 1 中的图像 2,2
    • Remove the four 19mm Phillips #2 screws from the base of the device.
  2. Bose Wave Radio AWR1-1W Speaker Replacement: 步骤 2 中的图像 1,3 Bose Wave Radio AWR1-1W Speaker Replacement: 步骤 2 中的图像 2,3 Bose Wave Radio AWR1-1W Speaker Replacement: 步骤 2 中的图像 3,3
    • Turn the device over, holding the base on with your thumbs.
    • Hold the device tightly to prevent the base from falling off.
  3. Bose Wave Radio AWR1-1W Speaker Replacement: 步骤 3 中的图像 1,3 Bose Wave Radio AWR1-1W Speaker Replacement: 步骤 3 中的图像 2,3 Bose Wave Radio AWR1-1W Speaker Replacement: 步骤 3 中的图像 3,3
    • Gently lift the top off of the device.
    • Lift in the direction shown to avoid damaging the wires connecting the top and base of the device.
  4. Bose Wave Radio AWR1-1W Speaker Replacement: 步骤 4 中的图像 1,3 Bose Wave Radio AWR1-1W Speaker Replacement: 步骤 4 中的图像 2,3 Bose Wave Radio AWR1-1W Speaker Replacement: 步骤 4 中的图像 3,3
    • Pinch and unplug the white connector from the device.
  5. Bose Wave Radio AWR1-1W Speaker Replacement: 步骤 5 中的图像 1,3 Bose Wave Radio AWR1-1W Speaker Replacement: 步骤 5 中的图像 2,3 Bose Wave Radio AWR1-1W Speaker Replacement: 步骤 5 中的图像 3,3
    • Gently pinch and pull on the white ribbon cable to disconnect it from the base.
  6. Bose Wave Radio AWR1-1W Speaker Replacement: 步骤 6 中的图像 1,1
    • The base should now be completely detached from the device.
  7. Bose Wave Radio AWR1-1W Speaker Replacement, Front Grill: 步骤 7 中的图像 1,3 Bose Wave Radio AWR1-1W Speaker Replacement, Front Grill: 步骤 7 中的图像 2,3 Bose Wave Radio AWR1-1W Speaker Replacement, Front Grill: 步骤 7 中的图像 3,3
    • Wedge the spudger between the top and front panel on the right side of the device.
    • Push down on the spudger, lifting the front panel away from the top panel until it pops out of the right side.
    • Repeat for the left side of the device.
    • Too much pressure may break the panel, but it should flex slightly before it pops out.
  8. Bose Wave Radio AWR1-1W Speaker Replacement: 步骤 8 中的图像 1,3 Bose Wave Radio AWR1-1W Speaker Replacement: 步骤 8 中的图像 2,3 Bose Wave Radio AWR1-1W Speaker Replacement: 步骤 8 中的图像 3,3
    • Once the panel is released on the left side, wedge the spudger between the top panel and front grill of the device as shown.
    • Apply pressure and move the spudger upward until the front grill pops out.
    • Repeat for the right side of the device.
  9. Bose Wave Radio AWR1-1W Speaker Replacement: 步骤 9 中的图像 1,1
    • Lift the front grill away from the device.
  10. Bose Wave Radio AWR1-1W Speaker Replacement, Speakers: 步骤 10 中的图像 1,3 Bose Wave Radio AWR1-1W Speaker Replacement, Speakers: 步骤 10 中的图像 2,3 Bose Wave Radio AWR1-1W Speaker Replacement, Speakers: 步骤 10 中的图像 3,3
    • Remove a total of eight 15mm Phillips #2 screws surrounding each speaker.
  11. Bose Wave Radio AWR1-1W Speaker Replacement: 步骤 11 中的图像 1,3 Bose Wave Radio AWR1-1W Speaker Replacement: 步骤 11 中的图像 2,3 Bose Wave Radio AWR1-1W Speaker Replacement: 步骤 11 中的图像 3,3
    • Gently pull each speaker out of the device.
  12. Bose Wave Radio AWR1-1W Speaker Replacement: 步骤 12 中的图像 1,3 Bose Wave Radio AWR1-1W Speaker Replacement: 步骤 12 中的图像 2,3 Bose Wave Radio AWR1-1W Speaker Replacement: 步骤 12 中的图像 3,3
    • Pull the wire connected to the speakers out of the device.
    • You already disconnected this wire from the inside of the device earlier.
结论
6等其他人完成本指南。
Cassie Harriman
于04/18/17注册
1,033 声望
创作了5篇指南
团队
Cal Poly, Team S15-G2, Banghart Spring 2017 Cal Poly, Team S15-G2, Banghart Spring 2017 的会员
CPSU-BANGHART-S17S15G2
4 名成员
创作了6篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 15
过去 30 天: 77
总计 6,892
