跳转到主内容
Bose Wave Radio AWR1-1W Screen Replacement
你所需要的
  1. Bose Wave Radio AWR1-1W Screen Replacement, Base: 步骤 1 中的图像 1,2 Bose Wave Radio AWR1-1W Screen Replacement, Base: 步骤 1 中的图像 2,2
    • Remove the four 19mm Phillips #2 screws from the base of the device.
  2. Bose Wave Radio AWR1-1W Screen Replacement: 步骤 2 中的图像 1,3 Bose Wave Radio AWR1-1W Screen Replacement: 步骤 2 中的图像 2,3 Bose Wave Radio AWR1-1W Screen Replacement: 步骤 2 中的图像 3,3
    • Turn the device over, holding the base on with your thumbs.
    • Hold the device tightly to prevent the base from falling off.
  3. Bose Wave Radio AWR1-1W Screen Replacement: 步骤 3 中的图像 1,3 Bose Wave Radio AWR1-1W Screen Replacement: 步骤 3 中的图像 2,3 Bose Wave Radio AWR1-1W Screen Replacement: 步骤 3 中的图像 3,3
    • Gently lift the top off of the device.
    • Lift in the direction shown to avoid damaging the wires connecting the top and base of the device.
  4. Bose Wave Radio AWR1-1W Screen Replacement: 步骤 4 中的图像 1,3 Bose Wave Radio AWR1-1W Screen Replacement: 步骤 4 中的图像 2,3 Bose Wave Radio AWR1-1W Screen Replacement: 步骤 4 中的图像 3,3
    • Pinch and unplug the white connector from the device.
  5. Bose Wave Radio AWR1-1W Screen Replacement: 步骤 5 中的图像 1,3 Bose Wave Radio AWR1-1W Screen Replacement: 步骤 5 中的图像 2,3 Bose Wave Radio AWR1-1W Screen Replacement: 步骤 5 中的图像 3,3
    • Gently pinch and pull on the white ribbon cable to disconnect it from the base.
  6. Bose Wave Radio AWR1-1W Screen Replacement: 步骤 6 中的图像 1,1
    • The base should now be completely detached from the device.
  7. Bose Wave Radio AWR1-1W Screen Replacement, Front Grill: 步骤 7 中的图像 1,3 Bose Wave Radio AWR1-1W Screen Replacement, Front Grill: 步骤 7 中的图像 2,3 Bose Wave Radio AWR1-1W Screen Replacement, Front Grill: 步骤 7 中的图像 3,3
    • Wedge the spudger between the top and front panel on the right side of the device.
    • Push down on the spudger, lifting the front panel away from the top panel until it pops out of the right side.
    • Repeat for the left side of the device.
    • Too much pressure may break the panel, but it should flex slightly before it pops out.
  8. Bose Wave Radio AWR1-1W Screen Replacement: 步骤 8 中的图像 1,3 Bose Wave Radio AWR1-1W Screen Replacement: 步骤 8 中的图像 2,3 Bose Wave Radio AWR1-1W Screen Replacement: 步骤 8 中的图像 3,3
    • Once the panel is released on the left side, wedge the spudger between the top panel and front grill of the device as shown.
    • Apply pressure and move the spudger upward until the front grill pops out.
    • Repeat for the right side of the device.
  9. Bose Wave Radio AWR1-1W Screen Replacement: 步骤 9 中的图像 1,1
    • Lift the front grill away from the device.
  10. Bose Wave Radio AWR1-1W Screen Replacement, Button Panel: 步骤 10 中的图像 1,2 Bose Wave Radio AWR1-1W Screen Replacement, Button Panel: 步骤 10 中的图像 2,2
    • Turn the device around.
    • Wedge the spudger into the larger part of the gap under the back of the device.
  11. Bose Wave Radio AWR1-1W Screen Replacement: 步骤 11 中的图像 1,1
    • Move the spudger up until the button panel is loose.
    • Push forward on the back of the button panel to disconnect the panel from the top of the device.
  12. Bose Wave Radio AWR1-1W Screen Replacement: 步骤 12 中的图像 1,2 Bose Wave Radio AWR1-1W Screen Replacement: 步骤 12 中的图像 2,2
    • Pull the button panel forward with one hand and push the screen assembly into the device with the other to disconnect the button panel.
  13. Bose Wave Radio AWR1-1W Screen Replacement, Screen: 步骤 13 中的图像 1,3 Bose Wave Radio AWR1-1W Screen Replacement, Screen: 步骤 13 中的图像 2,3 Bose Wave Radio AWR1-1W Screen Replacement, Screen: 步骤 13 中的图像 3,3
    • Gently pull the top of the screen assembly away from the device.
  14. Bose Wave Radio AWR1-1W Screen Replacement: 步骤 14 中的图像 1,2 Bose Wave Radio AWR1-1W Screen Replacement: 步骤 14 中的图像 2,2
    • Lift the screen assembly upward and pull the white wire strip out of the device.
结论
4等其他人完成本指南。
Cassie Harriman
于04/18/17注册
1,033 声望
创作了5篇指南
团队
Cal Poly, Team S15-G2, Banghart Spring 2017 Cal Poly, Team S15-G2, Banghart Spring 2017 的会员
CPSU-BANGHART-S17S15G2
4 名成员
创作了6篇指南
5条评论
Great! This device is the best wave system in sound accurate. All frequencies sounds clear!!! Awesome!!!
srmrs - 回复
Nicely done.  Love the details.  Just one question - where can I get the replacement screen?
Patsy Hamilton - 回复
Instructions were PERFECT! Thank you. I found my replacement screen on ebay for $25, took a chance that it would work as stated by the seller. Otherwise I would have thrown the radio away.
John Stine - 回复
I performed the repair as directed. It was easy especially if you have a plastic spung to work with. Problem comes from the new display once installed shows all the characters? Unplugged it and re-plugged but still stuck in all character test mode?
plhamp - 回复
How to purchase White wire strip
Bruce Ebneter - 回复
添加评论
浏览统计数据:
过去 24 小时: 3
过去 7 天: 15
过去 30 天: 67
总计 10,261
