跳转到主内容
Bose Soundlink Revolve AUX/USB Port Replacement
你所需要的
  1. Bose Soundlink Revolve AUX/USB Port Replacement, Bottom Circuit Board Access: 步骤 1 中的图像 1,2 Bose Soundlink Revolve AUX/USB Port Replacement, Bottom Circuit Board Access: 步骤 1 中的图像 2,2
    • Flip speaker over so that the bottom is facing up.
    • Using the blue spudger, lift the gray foam up and slowly peel it off with your hand.
  2. Bose Soundlink Revolve AUX/USB Port Replacement: 步骤 2 中的图像 1,3 Bose Soundlink Revolve AUX/USB Port Replacement: 步骤 2 中的图像 2,3 Bose Soundlink Revolve AUX/USB Port Replacement: 步骤 2 中的图像 3,3
    • Using the screwdriver, unscrew three screws.
    • Detach the bottom cover from the rest of the speaker by pulling the two in opposite directions.
  3. Bose Soundlink Revolve AUX/USB Port Replacement: 步骤 3 中的图像 1,2 Bose Soundlink Revolve AUX/USB Port Replacement: 步骤 3 中的图像 2,2
    • Remove the screw that is above the charging port.
  4. Bose Soundlink Revolve AUX/USB Port Replacement: 步骤 4 中的图像 1,2 Bose Soundlink Revolve AUX/USB Port Replacement: 步骤 4 中的图像 2,2
    • Remove the two screws connecting the motherboard to the bottom cover of the speaker.
    • Remove the bottom cover.
  5. Bose Soundlink Revolve AUX/USB Port Replacement, AUX/USB Port: 步骤 5 中的图像 1,3 Bose Soundlink Revolve AUX/USB Port Replacement, AUX/USB Port: 步骤 5 中的图像 2,3 Bose Soundlink Revolve AUX/USB Port Replacement, AUX/USB Port: 步骤 5 中的图像 3,3
    • Using the blue plastic opening tool, pry up the small black clamp connecting the AUX/USB port to the lower circuit board.
    • Remove the AUX/USB port from the device.
结论
14等其他人完成本指南。
Brian Butner
于09/27/17注册
861 声望
创作了3篇指南
团队
USF Tampa, Team S6-G2, Remmell Fall 2017 USF Tampa, Team S6-G2, Remmell Fall 2017 的会员
USFT-REMMELL-F17S6G2
4 名成员
创作了4篇指南
17条评论
Any idea where I can find the USB/Aux board for sale?
Chad - 回复
Did you ever manage to find a place to buy it?
Steve Fantin -
You can buy a charging cradle for this device, maybe that helps..
adsf -
I am also looking for the usb port replacement part.
James Nowicki - 回复
添加评论
浏览统计数据:
过去 24 小时: 10
过去 7 天: 69
过去 30 天: 333
总计 31,909
