跳转到主内容
Bose Soundlink Mini II charging port Replacement
你所需要的
    • flip the speaker over onto its back, then open the rubber covering the battery.
    • unscrew the battery using your screwdriver. carefully disconnect the battery from the motherboard.
    • be very careful not to damage the connector.
    • when replacing the battery, re apply the adhesive strip.
    • leave the battery aside.
    • carefully using a spludger, pry up the rubber holding the grills in place. then pry off the grill.
    • Be very careful with the grill as they bend easily.
    • using your spludger, carefully disconnect the ribbon cable connecting to the motherboard.
    • carefully remove the charging port assembly.
    • be VERY careful not to damage disconnecting the ribbon cable from the connector.
    • carefully pull out the charging port assembly.
    • be Extremely careful when attaching the new port to the assembly.
    • when replacing the port assembly, add the adhesive under the port.
结论
另外一个人完成了本指南。
776831
于06/10/21注册
1,085 声望
创作了8篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 13
过去 30 天: 68
总计 1,062
