跳转到主内容
Bose Soundlink II Battery Replacement
你所需要的
  1. Bose Soundlink II Battery Replacement, Bose Soundlink II Cover Removal: 步骤 1 中的图像 1,1
    • Using a 2.5 mm hex wrench, remove the two 13 mm screws from the bottom of the speaker.
  2. Bose Soundlink II Battery Replacement: 步骤 2 中的图像 1,1
    • Push up on the back of the cover until it slides up slightly.
    • Pull the cover up and away from the speaker backing.
  3. Bose Soundlink II Battery Replacement, Battery: 步骤 3 中的图像 1,1
    • Using the screwdriver with the T-10 star tip, remove the 6.75 mm. screws marked in red.
  4. Bose Soundlink II Battery Replacement: 步骤 4 中的图像 1,2 Bose Soundlink II Battery Replacement: 步骤 4 中的图像 2,2
    • Carefully remove the battery by pulling it out of the speaker.
结论
16等其他人完成本指南。
Kevin Bailey
于09/24/15注册
488 声望
创作了2篇指南
团队
Texas Tech, Team 22-4, Rauch Fall 2015 Texas Tech, Team 22-4, Rauch Fall 2015 的会员
TTU-RAUCH-F15S22G4
3 名成员
创作了5篇指南
11指南评论
Where i can buy one them battery model?
Daniel Campos - 回复
Just ordered a “Used, in good shape”, and it seems to be, however, it’s the REALLY original model, with the solid flap on the front, that turns into the stand. SN: 054867920870604AE. Guessing this is NOT the “Soundlink II”, but the original model. Instructions that came with it claim battery will last up to 3 hours. JUST IN CASE this battery is shot, was looking into what’s involved to replace it. However, mine being older, wondering if this battery would still fit?
      Thanks, Bob.
bobveitch4 - 回复
How do I get a used replacement battery for this in Nigeria? Please contact me on johnpaulokenyodo@gmail.com if any. Thanks
Okenyodo Johnpaul - 回复
I bought an Replacement battery which brand is Emaks from Amazon and do it following the guide,It works well now!Thank you!!!
Emily - 回复
How much the battery only
Joboy De Guzman II - 回复
添加评论
浏览统计数据:
过去 24 小时: 9
过去 7 天: 78
过去 30 天: 310
总计 36,555
