跳转到主内容
Bose SoundTouch Portable Speaker Replacement
你所需要的
  1. Bose SoundTouch Portable Speaker Replacement, Speaker Battery: 步骤 1 中的图像 1,1
    • Remove the two T-10 machine screws at the bottom of the device.
  2. Bose SoundTouch Portable Speaker Replacement: 步骤 2 中的图像 1,1
    • Turn the device around.
    • From the top, lightly push down the back cover to release it.
    • Lift the bottom of the cover and pull it up.
  3. Bose SoundTouch Portable Speaker Replacement: 步骤 3 中的图像 1,1
    • Remove the two T-10 machine screws, then pull the battery straight out.
  4. Bose SoundTouch Portable Speaker Replacement, Grille: 步骤 4 中的图像 1,1
    • Remove the two screws holding the speaker grille in place.
  5. Bose SoundTouch Portable Speaker Replacement: 步骤 5 中的图像 1,1
    • Grip the sides of the device and push the speaker grille down and out.
  6. Bose SoundTouch Portable Speaker Replacement: 步骤 6 中的图像 1,1
    • Gently release the ribbon from its connector and remove the grille.
  7. Bose SoundTouch Portable Speaker Replacement, Speakers: 步骤 7 中的图像 1,1
    • There are four T-10 Torx screws for each speaker; remove all four screws for each speaker you are replacing.
  8. Bose SoundTouch Portable Speaker Replacement: 步骤 8 中的图像 1,3 Bose SoundTouch Portable Speaker Replacement: 步骤 8 中的图像 2,3 Bose SoundTouch Portable Speaker Replacement: 步骤 8 中的图像 3,3
    • Using a plastic pry tool, carefully pry the speaker up.
    • With the bottom of the speaker exposed, unwind the wires from the connection tabs and replace the speaker.
结论
另外一个人完成了本指南。
Chelsea Martin
于02/20/17注册
697 声望
创作了6篇指南
团队
USF Tampa, Team S1-G3, Leahy Spring 2017 USF Tampa, Team S1-G3, Leahy Spring 2017 的会员
USFT-LEAHY-S17S1G3
3 名成员
创作了9篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 3
过去 30 天: 14
总计 1,829
