跳转到主内容
Bose SoundTouch Portable Motherboard Replacement
你所需要的
  1. Bose SoundTouch Portable Motherboard Replacement, Speaker Battery: 步骤 1 中的图像 1,1
    • Remove the two T-10 machine screws at the bottom of the device.
  2. Bose SoundTouch Portable Motherboard Replacement: 步骤 2 中的图像 1,1
    • Turn the device around.
    • From the top, lightly push down the back cover to release it.
    • Lift the bottom of the cover and pull it up.
  3. Bose SoundTouch Portable Motherboard Replacement: 步骤 3 中的图像 1,1
    • Remove the two T-10 machine screws, then pull the battery straight out.
  4. Bose SoundTouch Portable Motherboard Replacement, Metal Trim: 步骤 4 中的图像 1,1
    • Remove the two screws using a torx screwdriver.
  5. Bose SoundTouch Portable Motherboard Replacement: 步骤 5 中的图像 1,1
    • With the bottom of the device facing you, pull down the trim pieces to remove from the device body.
  6. Bose SoundTouch Portable Motherboard Replacement, Motherboard: 步骤 6 中的图像 1,2 Bose SoundTouch Portable Motherboard Replacement, Motherboard: 步骤 6 中的图像 2,2
    • Remove four T-10 Torx screws; there are two on the front and two on the back.
  7. Bose SoundTouch Portable Motherboard Replacement: 步骤 7 中的图像 1,3 Bose SoundTouch Portable Motherboard Replacement: 步骤 7 中的图像 2,3 Bose SoundTouch Portable Motherboard Replacement: 步骤 7 中的图像 3,3
    • Pinch and remove the connectors.
    • Use a flat tool to pry off the top piece.
  8. Bose SoundTouch Portable Motherboard Replacement: 步骤 8 中的图像 1,3 Bose SoundTouch Portable Motherboard Replacement: 步骤 8 中的图像 2,3 Bose SoundTouch Portable Motherboard Replacement: 步骤 8 中的图像 3,3
    • Remove the four T-10 Torx screws holding the plastic cover in place.
    • Remove the one T-10 Torx screw that is holding the motherboard in place.
    • Pry off the motherboard.
结论
2等其他人完成本指南。
Chelsea Martin
于02/20/17注册
697 声望
创作了6篇指南
团队
USF Tampa, Team S1-G3, Leahy Spring 2017 USF Tampa, Team S1-G3, Leahy Spring 2017 的会员
USFT-LEAHY-S17S1G3
3 名成员
创作了9篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 9
过去 30 天: 34
总计 2,958
