简介
If the front mesh is dirty on your Bose SoundTouch 10, the front panel may need to be removed for cleaning with a fine bristle brush or compressed air.
You may also need to remove the front panel for access to parts inside the speaker that may need to be replaced.
你所需要的
Turn the speaker over so that the rubber strips along the bottom are facing you.
Use the iFixit Opening Tool to peel back the rubber strip on the bottom-front edge.
另外一个人完成了本指南。
