简介
If your speaker is not receiving power or is charging slowly, make sure that it is not the power cord that is the cause of the problem. After that if the problem persists, the charging port may need to be replaced.
The motherboard in this guide contains capacitors which can hold a charge even when the speaker is powered off. Do not touch the as it may result in a shock.
你所需要的
Turn the speaker over so that the rubber strips along the bottom are facing you.
Use the iFixit Opening Tool to peel back the rubber strip on the bottom-front edge.
Use a #2 Phillips screwdriver to remove each of the six 20mm screws located underneath the front panel.
Use a #0 Phillips screwdriver to remove each of the two 11mm screws attached to the bass port.
Pinch the tab on the bottom of the clip connecting the charging port cables to the motherboard.
Lift upwards to disconnect the clip.
另外一个人完成了本指南。
