跳转到主内容
Bose SoundTouch 10 Bass Port Replacement
你所需要的
  1. Bose SoundTouch 10 Bass Port Replacement, Front Panel: 步骤 1 中的图像 1,1
    • Turn the speaker over so that the rubber strips along the bottom are facing you.
    • Use the iFixit Opening Tool to peel back the rubber strip on the bottom-front edge.
  2. Bose SoundTouch 10 Bass Port Replacement: 步骤 2 中的图像 1,1
    • Use a #2 Phillips screwdriver to remove each of the three 20mm screws on the bottom front edge of the speaker.
  3. Bose SoundTouch 10 Bass Port Replacement: 步骤 3 中的图像 1,2 Bose SoundTouch 10 Bass Port Replacement: 步骤 3 中的图像 2,2
    • Slide the front panel with the mesh covering downwards to disconnect it from the SoundTouch 10 body.
    • Lift the panel away to reveal the speaker head.
  4. Bose SoundTouch 10 Bass Port Replacement, Back panel: 步骤 4 中的图像 1,1
    • Use a #2 Phillips screwdriver to remove each of the six 20mm screws located underneath the front panel.
  5. Bose SoundTouch 10 Bass Port Replacement: 步骤 5 中的图像 1,1
    • Flip the speaker onto its back.
    • Loosen the adhesive by sliding a Metal Spudger under the edge where the back panel meets the speaker's body.
  6. Bose SoundTouch 10 Bass Port Replacement: 步骤 6 中的图像 1,2 Bose SoundTouch 10 Bass Port Replacement: 步骤 6 中的图像 2,2
    • Use force with an iFixit Plastic Opening Tool to pry the back panel up from the speaker frame.
    • If the panel does not come free easily, a heat gun may be needed to weaken the adhesive.
    • Once the panel has been disconnected, it should fall open revealing the motherboard.
  7. Bose SoundTouch 10 Bass Port Replacement: 步骤 7 中的图像 1,2 Bose SoundTouch 10 Bass Port Replacement: 步骤 7 中的图像 2,2
    在这个步骤中使用的工具:
    购买
    • Use ESD Safe Tweezers (Blunt Nose) to pull out the wire ribbon at the end of the motherboard.
  8. Bose SoundTouch 10 Bass Port Replacement: 步骤 8 中的图像 1,2 Bose SoundTouch 10 Bass Port Replacement: 步骤 8 中的图像 2,2
    • The motherboard contains capacitors (shown as cylinders in the upper right of the picture) which can hold a charge even when the speaker is powered off. Do not touch them as doing so may result in a shock.
    • Pull up on the base of the speaker wire plug to disconnect it from the motherboard.
  9. Bose SoundTouch 10 Bass Port Replacement, Bass Port: 步骤 9 中的图像 1,1
    • Use a #0 Phillips screwdriver to remove each of the two 11mm screws attached to the bass port.
  10. Bose SoundTouch 10 Bass Port Replacement: 步骤 10 中的图像 1,1
    • Lift the bass port away from the motherboard.
结论
2等其他人完成本指南。
James Asbury
于04/10/17注册
898 声望
创作了5篇指南
团队
Cal Poly, Team S13-G1, Forte Spring 2017 Cal Poly, Team S13-G1, Forte Spring 2017 的会员
CPSU-FORTE-S17S13G1
4 名成员
创作了5篇指南
一条评论
I whant purchase capacitor 330
35v
Chandan Kumar - 回复
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 5
过去 30 天: 25
总计 3,808
