本指南有最近更改,您可查看未经巡查的最新版本。
简介
Use this guide to replace the front or back mesh grilles. Make sure you have the required tools. The first time you remove a grille might be a little difficult due to some glue holding it in place. Be careful when removing, as the grille may bend easily.
你所需要的
Insert the Metal Spudger between the rubber edge on the grille and the aluminum casing.
9等其他人完成本指南。
6条评论
Hi brilliant advise. Where can I get hold of the front perl white grill? I can't find it anywhere!
Hi brilliant advise. Where can I get hold of the front perl white grill of my soundlink mini ? I can't find it anywhere!
Where can I purchase the grill?
Take out the grills, put a peace of tape on logo properly cut it, and repaint it. Apply a thin coat of spray paint only.
