跳转到主内容
Bose SoundLink Mini Front/Back Protective Grille Replacement
你所需要的
  1. Bose SoundLink Mini Front/Back Protective Grille Replacement, Front/Back Protective Grille: 步骤 1 中的图像 1,1
    • Insert the Metal Spudger between the rubber edge on the grille and the aluminum casing.
    • Place Metal Spudger in the location shown.
  2. Bose SoundLink Mini Front/Back Protective Grille Replacement: 步骤 2 中的图像 1,2 Bose SoundLink Mini Front/Back Protective Grille Replacement: 步骤 2 中的图像 2,2
    • Slowly pry up the grille until the two tabs shown pop out.
    • Be very gentle, the grille will bend.
  3. Bose SoundLink Mini Front/Back Protective Grille Replacement: 步骤 3 中的图像 1,2 Bose SoundLink Mini Front/Back Protective Grille Replacement: 步骤 3 中的图像 2,2
    • The grille is attached to the speaker with double sided sticky tape. To remove the grill gently pull upward while keeping tension to the right.
  4. Bose SoundLink Mini Front/Back Protective Grille Replacement: 步骤 4 中的图像 1,2 Bose SoundLink Mini Front/Back Protective Grille Replacement: 步骤 4 中的图像 2,2
    • Repeat steps to remove the back grille.
结论
9等其他人完成本指南。
Jordan Smith
于10/01/15注册
895 声望
创作了4篇指南
团队
Cal Poly, Team 1-23, Maness Fall 2015 Cal Poly, Team 1-23, Maness Fall 2015 的会员
CPSU-MANESS-F15S1G23
4 名成员
创作了21篇指南
6条评论
Has anyone an idea where to buy new meshs for the dark version of Bose SL II ? My are badly scratched and I'd like to replace them.. dont know where to buy them though..
krisskuli - 回复
Hi brilliant advise. Where can I get hold of the front perl white grill? I can't find it anywhere!
Peter Bacher - 回复
Hi brilliant advise. Where can I get hold of the front perl white grill of my soundlink mini ? I can't find it anywhere!
Peter Bacher - 回复
Where can I purchase the grill?
Ronald Roden Jr - 回复
Take out the grills, put a peace of tape on logo properly cut it, and repaint it. Apply a thin coat of spray paint only.
Pranjal Vishwakarma - 回复
添加评论
浏览统计数据:
过去 24 小时: 3
过去 7 天: 11
过去 30 天: 100
总计 12,773
