跳转到主内容
Bose SoundLink Mini Battery Cover Replacement
你所需要的
  1. Bose SoundLink Mini Battery Cover Replacement, Battery: 步骤 1 中的图像 1,1
    • Peel back the rubber battery cover and remove the four circled 6.0 mm screws using a T8 Torx Screwdriver.
  2. Bose SoundLink Mini Battery Cover Replacement: 步骤 2 中的图像 1,2 Bose SoundLink Mini Battery Cover Replacement: 步骤 2 中的图像 2,2
    • While holding the cover back, pull straight up on the battery to remove it.
  3. Bose SoundLink Mini Battery Cover Replacement, Front/Back Protective Grille: 步骤 3 中的图像 1,1
    • Insert the Metal Spudger between the rubber edge on the grille and the aluminum casing.
    • Place Metal Spudger in the location shown.
  4. Bose SoundLink Mini Battery Cover Replacement: 步骤 4 中的图像 1,2 Bose SoundLink Mini Battery Cover Replacement: 步骤 4 中的图像 2,2
    • Slowly pry up the grille until the two tabs shown pop out.
    • Be very gentle, the grille will bend.
  5. Bose SoundLink Mini Battery Cover Replacement: 步骤 5 中的图像 1,2 Bose SoundLink Mini Battery Cover Replacement: 步骤 5 中的图像 2,2
    • The grille is attached to the speaker with double sided sticky tape. To remove the grill gently pull upward while keeping tension to the right.
  6. Bose SoundLink Mini Battery Cover Replacement: 步骤 6 中的图像 1,2 Bose SoundLink Mini Battery Cover Replacement: 步骤 6 中的图像 2,2
    • Repeat steps to remove the back grille.
  7. Bose SoundLink Mini Battery Cover Replacement, Battery Cover: 步骤 7 中的图像 1,2 Bose SoundLink Mini Battery Cover Replacement, Battery Cover: 步骤 7 中的图像 2,2
    • Remove the four 15.0 mm screws on the left and the four 9.0 mm screws on the right using the T8 Torx Screwdriver.
  8. Bose SoundLink Mini Battery Cover Replacement: 步骤 8 中的图像 1,2 Bose SoundLink Mini Battery Cover Replacement: 步骤 8 中的图像 2,2
    • Remove the circuit board by pushing it with your index finger in the direction shown while using a nylon or metal spudger to lift it up and out of place.
  9. Bose SoundLink Mini Battery Cover Replacement: 步骤 9 中的图像 1,2 Bose SoundLink Mini Battery Cover Replacement: 步骤 9 中的图像 2,2
    • Carefully pull on the battery cover until the rubber tab slides out of the aluminum casing.
结论
7等其他人完成本指南。
Jordan Smith
于10/01/15注册
895 声望
创作了4篇指南
团队
Cal Poly, Team 1-23, Maness Fall 2015 Cal Poly, Team 1-23, Maness Fall 2015 的会员
CPSU-MANESS-F15S1G23
4 名成员
创作了21篇指南
3条评论
can someone tell me how do i reattach the rubber battery cover if i have removed it completely
rajpotus - 回复
Cut the lip off. You will not be able to put it back. It’s Bose’s terrible design.
megaspeed - 回复
@rajpotus: I had the same problem. If the little rubber tab is not damaged (mine was fine), you should be able to follow these instructions to replace it. But I have these comments on the instructions:
1) You do NOT need to remove the front grill. I have no idea why they suggest you do that here.
2) I think the reason you remove the battery is to make sure the circuit board has zero power on it when you work on it — otherwise a touch of the screwdriver to an unlucky spot on the board might short/burn something out. But I don’t think there’s any mechanical reason to remove it.
3) Once you pop off the back grill cover, you should be able to slide the tab through the slot and coax it up (maybe with a tooth-pick and/or tweezers) on top of the circuit board, but it’s probably better to unscrew the circuit board (as directed here) which makes it easier to push the rubber tab through. Then slide the circuit board back under the tab and screw it back into place.
Matthew Busche - 回复
添加评论
浏览统计数据:
过去 24 小时: 7
过去 7 天: 55
过去 30 天: 187
总计 16,257
