跳转到主内容
当前版本的文档还未经巡查,您可以查看最新的已查核版本
你所需要的
  1. 这个步骤还没有翻译 帮忙翻译一下
    : 步骤 1 中的图像 1,2 : 步骤 1 中的图像 2,2
    • Four round, plastic plugs are located on the back of the device.
    • Using a metal spudger, carefully pry up the plastic covers.
    • The covers are all glued on, so be careful not to scar the casing when prying them off. If possible, use a spudger or plastic opening tool to remove them.
  2. 这个步骤还没有翻译 帮忙翻译一下
    : 步骤 2 中的图像 1,2 : 步骤 2 中的图像 2,2
    • Remove the four 1.8 cm-long T15 Torx Security screws from the outer case.
    • Some of these use T15 "Star" 5-point Torx security screws instead of the more common 6-point ones.
  3. 这个步骤还没有翻译 帮忙翻译一下
    : 步骤 3 中的图像 1,2 : 步骤 3 中的图像 2,2
    • Carefully open up the casing.
    • The top button pad may need to be re-glued upon installing the new casing.
  4. 这个步骤还没有翻译 帮忙翻译一下
    : 步骤 4 中的图像 1,1
    • Carefully remove the battery using a pair of tweezers.
    • Lift the inner assembly from the outer casing.
  5. 这个步骤还没有翻译 帮忙翻译一下
    : 步骤 5 中的图像 1,1
    • Partially cut the battery cover on the side paying attention to do not damage the circuit or the battery. Cut the cover just enough to remove it, try to not damage it too much as it is going to be reused.
  6. 这个步骤还没有翻译 帮忙翻译一下
    : 步骤 6 中的图像 1,3 : 步骤 6 中的图像 2,3 : 步骤 6 中的图像 3,3
    • Desolder the battery leads from the PCB and remove the battery.
  7. 这个步骤还没有翻译 帮忙翻译一下
    : 步骤 7 中的图像 1,1
    • I opted for a Panasonic NCR18650B, choose the version with solder tabs, otherwise it will be a pain to solder wires on the battery and you'll probably go out from the factory dimensions. From the benchmarks it looks like a very good battery, time will tell.
    • Fit the new battery, cut the leads to the needed length, pay attention to polarity. You may need to enlarge leads holes in the plastic case with a cutter to let standard battery leads thru.
  8. 这个步骤还没有翻译 帮忙翻译一下
    : 步骤 8 中的图像 1,1
    • Put back the sponge cover, it is necessary to avoid vibrations and to keep the thing firmly in place.
终点
87等其他人完成本指南。
61条评论
Any recommendations where to pick up/order a replacement battery from?
Rob Miller - 回复
See the link in the description, it is available thru Amazon
Giacomo di ciocco -
Has anyone found where to order battery from?
amitos80 - 回复
Put battery part number in google and search it on ebay. It will come up with your replacement
Ron Emerson -
Mine still works fine, but I'd like to know like the others here where to get a battery that will work as a replacement.
chandlerwebb - 回复
添加评论
浏览统计数据:
过去 24 小时: 59
过去 7 天: 398
过去 30 天: 1,819
总计 187,906
