跳转到主内容
Bose SoundLink Color Button Pad Replacement
你所需要的
  1. Bose SoundLink Color  Button Pad Replacement, Outer Casing: 步骤 1 中的图像 1,2 Bose SoundLink Color  Button Pad Replacement, Outer Casing: 步骤 1 中的图像 2,2
    • Four round, plastic plugs are located on the back of the device.
    • Using a metal spudger, carefully pry up the plastic covers.
    • The covers are all glued on, so be careful not to scar the casing when prying them off. If possible, use a spudger or plastic opening tool to remove them.
  2. Bose SoundLink Color  Button Pad Replacement: 步骤 2 中的图像 1,2 Bose SoundLink Color  Button Pad Replacement: 步骤 2 中的图像 2,2
    • Remove the four 1.8 cm-long T15 Torx Security screws from the outer case.
    • Some of these use T15 "Star" 5-point Torx security screws instead of the more common 6-point ones.
  3. Bose SoundLink Color  Button Pad Replacement: 步骤 3 中的图像 1,2 Bose SoundLink Color  Button Pad Replacement: 步骤 3 中的图像 2,2
    • Carefully open up the casing.
    • The top button pad may need to be re-glued upon installing the new casing.
  4. Bose SoundLink Color  Button Pad Replacement, Button Pad: 步骤 4 中的图像 1,2 Bose SoundLink Color  Button Pad Replacement, Button Pad: 步骤 4 中的图像 2,2
    • Lift up the retaining flap on the button cable ZIF connector.
    • Pull the button cable straight out of the connector.
  5. Bose SoundLink Color  Button Pad Replacement: 步骤 5 中的图像 1,2 Bose SoundLink Color  Button Pad Replacement: 步骤 5 中的图像 2,2
    • Carefully pull the ribbon cable through the rubber gasket that runs around the device.
  6. Bose SoundLink Color  Button Pad Replacement: 步骤 6 中的图像 1,1
    • To remove the old rubber button pad, carefully peel it off of the blue casing.
结论
To reassemble your device, follow these instructions in reverse order, starting from Step 6.
8等其他人完成本指南。
3条评论
Great guide, and I think I can manage this. But, where can I get the Replacement Bose SoundLink Color Button Pad??
Fred
Fred Fish - 回复
I’m wondering the same thing. Where do you get the replacement Bose Soundlink Color button pad? We just bought a new charger because we thought that was the problem. But that didn’t make any difference. We still can’t turn the speaker on!
Lynn Wilson - 回复
I got the bose soundlink color button panel only with bose India authorised service center in South Mumbai . That cost me in Indian RS. 2360. Including approx $35 USD.
nrirehan - 回复
添加评论
浏览统计数据:
过去 24 小时: 2
过去 7 天: 9
过去 30 天: 52
总计 10,034
