跳转到主内容
Bose SoundDock Portable v2 IR Receiver Replacement
你所需要的
  1. Bose SoundDock Portable v2 IR Receiver Replacement, IR Receiver: 步骤 1 中的图像 1,3 Bose SoundDock Portable v2 IR Receiver Replacement, IR Receiver: 步骤 1 中的图像 2,3 Bose SoundDock Portable v2 IR Receiver Replacement, IR Receiver: 步骤 1 中的图像 3,3
    • Gently pry the front mesh cover off of the sound dock using a metal spudger.
    • The mesh is held on by small velcro strips so if you hear a tearing sound it is just the velcro coming apart.
  2. Bose SoundDock Portable v2 IR Receiver Replacement: 步骤 2 中的图像 1,1
    • Using a T15 torx screwdriver, remove the 8mm screw holding the IR sensor to the speaker system.
  3. Bose SoundDock Portable v2 IR Receiver Replacement: 步骤 3 中的图像 1,1
    在这个步骤中使用的工具:
    • Using tweezers or your fingers, gently remove the ribbon cable connecting the IR sensor to the system.
结论
3等其他人完成本指南。
Evan Low
于04/14/15注册
584 声望
创作了4篇指南
团队
Cal Poly, Team 4-1, Maness Spring 2015 Cal Poly, Team 4-1, Maness Spring 2015 的会员
CPSU-MANESS-S15S4G1
4 名成员
创作了5篇指南
1指南评论
Hi my sounddock blocked suddenly and the green led always on. Do you now something about please... :(
jose - 回复
添加评论
浏览统计数据:
过去 24 小时: 3
过去 7 天: 3
过去 30 天: 30
总计 7,282
