简介
The following guide explains in detailed steps including pictures on how to replace the control panel of the Bose 5 Sound Bar. The control panel is responsible for controlling the power and the output of the Bose 5 Sound Bar. It may be necessary to replace the control panel if the sound bar does not produce sound when it is plugged into the TV. Upon completion of the control panel replacement, the Bose 5 Sound Bar should work as expected. Otherwise, it would indicate that your system has a different problem.
Before using this guide, be sure to test different audio cables that connect the sound bar to the TV to confirm that the faulty part is coming from the sound bar. Before beginning, make sure to disconnect the sound bar from the TV.
你所需要的
Lay Bose Solo 5 with speakers facing away from you and bottom side facing upward.
另外一个人完成了本指南。
5条评论
Does anyone know where to buy a replacement logic board? I’ve been searching for a while now, no dice.
hallo und wo bekomme ich das Ersatzteil die Platiene 73252 Delta 3
If anyone was able to find the board, it wuold be great to know where did you find it. Looking for this board during months...
