跳转到主内容
Bose Solo 5 Sound Bar Control Panel Replacement
你所需要的
  1. Bose Solo 5 Sound Bar Control Panel Replacement, Control Panel: 步骤 1 中的图像 1,1
    • Lay Bose Solo 5 with speakers facing away from you and bottom side facing upward.
  2. Bose Solo 5 Sound Bar Control Panel Replacement: 步骤 2 中的图像 1,2 Bose Solo 5 Sound Bar Control Panel Replacement: 步骤 2 中的图像 2,2
    • Remove the five 18.25mm screws with the Phillips #2 screw driver.
  3. Bose Solo 5 Sound Bar Control Panel Replacement: 步骤 3 中的图像 1,1
    • Remove the gold plates snap connector from the circuit board by pulling it apart.
  4. Bose Solo 5 Sound Bar Control Panel Replacement: 步骤 4 中的图像 1,1
    • Using the plastic opening tool, lift the circuit board up and remove from housing.
  5. Bose Solo 5 Sound Bar Control Panel Replacement: 步骤 5 中的图像 1,2 Bose Solo 5 Sound Bar Control Panel Replacement: 步骤 5 中的图像 2,2
    • Disconnect the cords running to the white connecter by pulling up on the tab until it is disconnected completely.
结论
另外一个人完成了本指南。
Emma
于10/05/18注册
500 声望
创作了3篇指南
团队
5条评论
Does anyone know where to buy a replacement logic board? I’ve been searching for a while now, no dice.
Tyler Barney - 回复
hallo und wo bekomme ich das Ersatzteil die Platiene 73252 Delta 3
APP TISCHNER - 回复
Has anyone had any luck finding the same board. Im looking.
ka.wells - 回复
I know how to open it. What I don't know is where to buy one.
szanti - 回复
If anyone was able to find the board, it wuold be great to know where did you find it. Looking for this board during months...
Juan Ramirez - 回复
添加评论
浏览统计数据:
过去 24 小时: 8
过去 7 天: 25
过去 30 天: 104
总计 13,104
