跳转到主内容
Bose QuietComfort 25 Battery Replacement
  1. Bose QuietComfort 25 Battery Replacement, Battery: 步骤 1 中的图像 1,2 Bose QuietComfort 25 Battery Replacement, Battery: 步骤 1 中的图像 2,2
    • Locate the side designation in the interior of the earpiece.
    • The battery compartment is located on the top of the right-side earpiece, accessible via the latched door.
  2. Bose QuietComfort 25 Battery Replacement: 步骤 2 中的图像 1,2 Bose QuietComfort 25 Battery Replacement: 步骤 2 中的图像 2,2
    • Do not allow battery corrosion to come into contact with your skin or eyes.
    • Sometimes, batteries or the terminals they come into contact with can become corroded. Corrosion will appear as chalky-white or green.
    • If the compartment is not clean--coated with debris or corroded--use a cotton swab to carefully remove debris or corrosion from the terminal corrosion.
  3. Bose QuietComfort 25 Battery Replacement: 步骤 3 中的图像 1,1
    • Insert a new battery.
    • Make sure that the polarity of the battery is aligned correctly to the diagram on the inside of the cartridge.
结论
When finished with this guide process, the Bose QuietComfort 25 should be able to be played with the functioning noise-cancelling feature.
9等其他人完成本指南。
一条评论
Are there any option for replacing the latch together with the spring?
I wanted to replace these after a battery leak, but I'm unable to find any sources for the part needed unless you want to buy a full set of headphones from some one else.
Erik - 回复
添加评论
浏览统计数据:
过去 24 小时: 8
过去 7 天: 34
过去 30 天: 131
总计 12,419
