跳转到主内容
Bose On-Ear headphones Ear Cushion Replacement
你所需要的
  1. Bose On-Ear headphones Ear Cushion Replacement, Ear Cushion: 步骤 1 中的图像 1,3 Bose On-Ear headphones Ear Cushion Replacement, Ear Cushion: 步骤 1 中的图像 2,3 Bose On-Ear headphones Ear Cushion Replacement, Ear Cushion: 步骤 1 中的图像 3,3
    • Here is the Bose Tricore OE headset. Slightly worn and a torn left ear cushion
    • To remove an existing ear cushion one would simply be applying a bit of force between the ear pads and the housing. The ear cushion will simply snap off
    • This shows the snaps that attach the ear pad to the case.
  2. Bose On-Ear headphones Ear Cushion Replacement: 步骤 2 中的图像 1,3 Bose On-Ear headphones Ear Cushion Replacement: 步骤 2 中的图像 2,3 Bose On-Ear headphones Ear Cushion Replacement: 步骤 2 中的图像 3,3
    • Since the ear cushion was already torn off on this one, simply clean the mating surfaces from all debris left by the old ear cushion
    • All left over foam and adhesive tape needs to be removed. This will ensure a proper fit.
    • Here is a look at the back of the replacement cushion.
  3. Bose On-Ear headphones Ear Cushion Replacement: 步骤 3 中的图像 1,3 Bose On-Ear headphones Ear Cushion Replacement: 步骤 3 中的图像 2,3 Bose On-Ear headphones Ear Cushion Replacement: 步骤 3 中的图像 3,3
    • Position the cushion so that the orientation aligns the two holes with the two pins on the headphones.
    • Place the new ear cushion on the headphones ensuring the holes and pins are lined up.
    • A simple squeeze on the ear cushion will snap the plastic to the headphones.
  4. Bose On-Ear headphones Ear Cushion Replacement: 步骤 4 中的图像 1,1
    • Good as new and ready to jam!
结论
另外一个人完成了本指南。
oldturkey03
于09/29/10注册
781,057 声望
创作了119篇指南
团队
Global Fixers Global Fixers 的会员
Community
32 名成员
创作了530篇指南
一条评论
Thanks for showing the steps
Rajiv Garg - 回复
添加评论
浏览统计数据:
过去 24 小时: 3
过去 7 天: 12
过去 30 天: 48
总计 7,278
