跳转到主内容
Bose Noise Cancelling Headphones 700 Ear Cushion Replacement
你所需要的
  1. Bose Noise Cancelling Headphones 700 Ear Cushion Replacement, Ear Cushion: 步骤 1 中的图像 1,2 Bose Noise Cancelling Headphones 700 Ear Cushion Replacement, Ear Cushion: 步骤 1 中的图像 2,2
    • Optional: Remove the band around the ear cushions if you find it to be in the way while replacing the ear cushions.
  2. Bose Noise Cancelling Headphones 700 Ear Cushion Replacement: 步骤 2 中的图像 1,1
    • Take the old ear cushions off of the headphones using an iFixit opening tool.
    • Using the tool, go around the ear cushions from the inside or the outside of the cushions, and gently pry them off.
  3. Bose Noise Cancelling Headphones 700 Ear Cushion Replacement: 步骤 3 中的图像 1,3 Bose Noise Cancelling Headphones 700 Ear Cushion Replacement: 步骤 3 中的图像 2,3 Bose Noise Cancelling Headphones 700 Ear Cushion Replacement: 步骤 3 中的图像 3,3
    • Make sure that the ear cushion is for the correct side if that is specified for the ear cushions you are using.
    • Align the ear cushion with the slots in the correct places and press it onto the headphones.
  4. Bose Noise Cancelling Headphones 700 Ear Cushion Replacement: 步骤 4 中的图像 1,1
    • If you took the band off the headphones, put it back on.
    • Repeat steps 1-3 for the other side of the headphones.
结论
Based on the reviews of the various replacement ear cushions for the Bose Noise Canceling Headphones 700, the replacement ear cushions from the Bose website are the best if the noise-canceling ability of the headphones is a necessity. Otherwise, any other manufacturer for the ear cushions will work perfectly fine as long as they are made for these specific headphones.
另外一个人完成了本指南。
Anjana Chilukuri
于07/05/23注册
139 声望
撰写一个指南
团队
一条评论
Anleitung ist sicher gut und zutreffend, zeigt aber leider keinen Bose 700 Kopfhörer.
Markus Scheuermann - 回复
添加评论
浏览统计数据:
过去 24 小时: 6
过去 7 天: 33
过去 30 天: 115
总计 1,472
