跳转到主内容
Bose Ae2w Bluetooth Module Battery Replacement
你所需要的
  1. Bose Ae2w Bluetooth Module Battery Replacement, Bluetooth Module Battery: 步骤 1 中的图像 1,1
    • Detach the Bluetooth module from the left earcup of the headphones.
    • Turn off the Bluetooth module before proceeding.
  2. Bose Ae2w Bluetooth Module Battery Replacement: 步骤 2 中的图像 1,2 Bose Ae2w Bluetooth Module Battery Replacement: 步骤 2 中的图像 2,2
    • Remove the five screws on the module using a small tri-wing bit and a Phillips head bit.
    • Using an opening tool, gently pry the cover from the sides and open the module.
  3. Bose Ae2w Bluetooth Module Battery Replacement: 步骤 3 中的图像 1,2 Bose Ae2w Bluetooth Module Battery Replacement: 步骤 3 中的图像 2,2
    • Gently lift the PCB to reveal the battery.
    • There may be a small piece of tape holding the PCB down that will need to be removed.
  4. Bose Ae2w Bluetooth Module Battery Replacement: 步骤 4 中的图像 1,2 Bose Ae2w Bluetooth Module Battery Replacement: 步骤 4 中的图像 2,2
    • The battery is secured with adhesive to the back of the module. Using the opening tool, gently pry off the battery.
    • Take care not to puncture the battery as you pry it off.
  5. Bose Ae2w Bluetooth Module Battery Replacement: 步骤 5 中的图像 1,1
    • Carefully desolder the two battery wires from the PCB.
结论
Ben Ponte
于03/24/25注册
509 声望
创作了4篇指南
团队
UMass Dartmouth, Team 5-4, Biswokarma Spring 2025 UMass Dartmouth, Team 5-4, Biswokarma Spring 2025 的会员
UMASSD-BISWOKARMA-S25S5G4
4 名成员
创作了5篇指南
3指南评论
These headphones are great and really comfortable. I replaced my battery a few years ago with a battery that I bought on eBay with the same 3.7V 140mAH specs that came with the headphones originally. However, this replacement, like the original, has very limited battery life - only a handful of hours (perhaps 3-6). Sometimes surprises me with low battery warnings when I think it should have sufficient charge. Hence, I'm looking at another replacement. When I look on Amazon now (Oct 2025), I see batteries advertised that appear to be compatible but with much larger capacity (350mAH). Do the authors know if the larger batteries are indeed compatible? My model was initially marketed as the AE2w and then renamed AE Soundlink and feature the huge detachable bluetooth module seen in the above photos. My concern is that there might be another wireless model also called the AE2 that has the receiver within the ear cup and with more physical space for a larger battery than my model couldn't accommodate.
Scobiwan - 回复
Hey,
I’m in the same place that you are. I bought the 350 mah from reference from others that used it yo fix their headphones but the battery is too large for the bluetooth module, it wont fit. I think the comments and references talk about newer headphones that hace the bluetood module built in, not like ours that can be removed.
I hope this gets you on time and save you some troubles. It’s ok to look for a battery with a bigger capacity than 140mah, just make sure it has a similar size than the original.
Cesar G -
Thanks for the information, Cesar... It seems we can conclude that the replacement battery we need is fundamentally limited by its physical dimensions in addition to its technical specs. I suspect that my hope of finding a battery with a higher capacity and, effectively, longer battery life well be futile if it must also conform to the same physical footprint... because physics. Oh, well, I guess the tiny 140mAH option will have to suffice. Shame.
If anyone is clever enough to squeeze a higher capacity battery into the Bluetooth module, please leave a comment with the battery details, I'm sure there are many people other than myself who would appreciate it.
Scobiwan - 回复
添加评论
浏览统计数据:
过去 24 小时: 2
过去 7 天: 22
过去 30 天: 72
总计 402
