跳转到主内容
Bosch PS21 Motor Replacement
你所需要的
  1. Bosch PS21 Motor Replacement, Battery: 步骤 1 中的图像 1,1
    • Pinch the two release tabs on the sides of the battery, and slide the battery out.
  2. Bosch PS21 Motor Replacement, Motor: 步骤 2 中的图像 1,2 Bosch PS21 Motor Replacement, Motor: 步骤 2 中的图像 2,2
    • After removing the battery pack, locate the clip that connects the two halves of the outer casing shown in the picture. Remove the clip using angled tweezers or a similar tool. Save the clip for reassembly.
  3. Bosch PS21 Motor Replacement: 步骤 3 中的图像 1,1
    • Locate the eight 5.5 mm screws as shown in the picture.
    • Remove each screw using a small Phillips head screw driver. Save all the screws for reassembly.
  4. Bosch PS21 Motor Replacement: 步骤 4 中的图像 1,2 Bosch PS21 Motor Replacement: 步骤 4 中的图像 2,2
    • Starting at the rear of the drill, use a wedge to separate the two halves of the outer case at the parting line.
  5. Bosch PS21 Motor Replacement: 步骤 5 中的图像 1,2 Bosch PS21 Motor Replacement: 步骤 5 中的图像 2,2
    • The motor and trigger assembly are connected by two wires. Do not pull or put tension on these wires.
    • Lift up the metal tab as shown in the first picture to free the trigger assembly.
    • Gently dislodge the motor and trigger assembly from the drill case. Remove the components as one piece, shown in the second picture.
  6. Bosch PS21 Motor Replacement: 步骤 6 中的图像 1,3 Bosch PS21 Motor Replacement: 步骤 6 中的图像 2,3 Bosch PS21 Motor Replacement: 步骤 6 中的图像 3,3
    • Be sure to not grip the pliers too firmly, as it could cause damage to the wire connectors.
    • Firmly secure the motor assembly in place. Using a set of pliers, carefully pull the black wire connector away from the motor. Repeat this action with the red wire connector.
    • The wire connections on the motor are color coded, matching the color wire that connects there.
  7. Bosch PS21 Motor Replacement: 步骤 7 中的图像 1,3 Bosch PS21 Motor Replacement: 步骤 7 中的图像 2,3 Bosch PS21 Motor Replacement: 步骤 7 中的图像 3,3
    • Once the wires have been disconnected, separate the trigger mechanism from the motor assembly.
    • Place your hands on each end of mechanism and carefully pull apart the assembly in order to separate the gearbox from the motor.
结论
另外一个人完成了本指南。
Daniel Sebastian
于02/15/16注册
133 声望
撰写一个指南
团队
IUPUI, Team 1-2, Harley Spring 2016 IUPUI, Team 1-2, Harley Spring 2016 的会员
IUPUI-HARLEY-S16S1G2
4 名成员
创作了4篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 3
过去 30 天: 15
总计 2,869
