简介
Bei Deinem Bosch PMF 180 E ist der Stecker beschädigt? Mit dieser Anleitung kannst Du ihn austauschen!
你所需要的
Arbeite die Schritte in umgekehrter Reihenfolge ab, um dein Gerät wieder zusammenzubauen.
2等其他人完成本指南。
附加文件
一条评论
To right of green holder there is a looped black and white wire that goes underneath. Where does it attach to as mine is loose below coil, between coil and case. Tool just stopped working mid use. No burning smell and no other loose connections. There is a moulding.on case that it fits into but no attachment anywhere. Coil has a small dent where small bend in wire appears to have sat
MsMacGyver - 回复
