跳转到主内容
Bosch 3727DEVS Motor Brushes Replacement
你所需要的
  1. Bosch 3727DEVS Motor Brushes  Replacement, Motor Brushes: 步骤 1 中的图像 1,3 Bosch 3727DEVS Motor Brushes  Replacement, Motor Brushes: 步骤 1 中的图像 2,3 Bosch 3727DEVS Motor Brushes  Replacement, Motor Brushes: 步骤 1 中的图像 3,3
    • Ensure that the power chord is not plugged into an outlet.
    • Using the T20 Torx Screwdriver, remove the four 15.6 mm screws securing the top cover to the sander.
    • Lift the top cover off the sander.
  2. Bosch 3727DEVS Motor Brushes  Replacement: 步骤 2 中的图像 1,3 Bosch 3727DEVS Motor Brushes  Replacement: 步骤 2 中的图像 2,3 Bosch 3727DEVS Motor Brushes  Replacement: 步骤 2 中的图像 3,3
    • Remove the two white wires connected to each motor brush by pulling on the spade terminals.
  3. Bosch 3727DEVS Motor Brushes  Replacement: 步骤 3 中的图像 1,3 Bosch 3727DEVS Motor Brushes  Replacement: 步骤 3 中的图像 2,3 Bosch 3727DEVS Motor Brushes  Replacement: 步骤 3 中的图像 3,3
    • Using the T10 Torx Screwdriver, remove the four 9.7 mm screws securing the motor brushes to the housing.
    • After the screws are removed, both motor brushes can be lifted out of their position by hand.
结论
另外一个人完成了本指南。
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 3
过去 30 天: 12
总计 1,043
