跳转到主内容
Bosch 3727DEVS Governor Replacement
你所需要的
  1. Bosch 3727DEVS Governor Replacement, Governor: 步骤 1 中的图像 1,3 Bosch 3727DEVS Governor Replacement, Governor: 步骤 1 中的图像 2,3 Bosch 3727DEVS Governor Replacement, Governor: 步骤 1 中的图像 3,3
    • Ensure that the power chord is not plugged into an outlet.
    • Using the T20 Torx Screwdriver, remove the four 15.6 mm screws securing the top cover to the sander.
    • Lift the top off of the sander.
  2. Bosch 3727DEVS Governor Replacement: 步骤 2 中的图像 1,3 Bosch 3727DEVS Governor Replacement: 步骤 2 中的图像 2,3 Bosch 3727DEVS Governor Replacement: 步骤 2 中的图像 3,3
    • Using the T20 Torx Screwdriver, remove the two 15.6 mm screws securing the cable clip to the motor housing.
    • Lift the cable clip and cord from motor housing.
  3. Bosch 3727DEVS Governor Replacement: 步骤 3 中的图像 1,1
    • Lift the On/Off switch out of the device
    • Remove the gray and purple wires
  4. Bosch 3727DEVS Governor Replacement: 步骤 4 中的图像 1,2 Bosch 3727DEVS Governor Replacement: 步骤 4 中的图像 2,2
    • Remove the gray, brown, and clear wires by pulling on the wire terminals.
    • Lift the Governor out of the housing.
结论
0条评论
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 1
过去 30 天: 13
总计 601
