跳转到主内容
Boot Zipper Replacement
你所需要的
  1. Boot Zipper Replacement, Zipper: 步骤 1 中的图像 1,2 Boot Zipper Replacement, Zipper: 步骤 1 中的图像 2,2
    • Using a seam ripper, carefully remove the stitching at the top of the boot on either side of the zipper.
    • Only remove enough to free the zipper, about ¾ of an inch.
  2. Boot Zipper Replacement: 步骤 2 中的图像 1,3 Boot Zipper Replacement: 步骤 2 中的图像 2,3 Boot Zipper Replacement: 步骤 2 中的图像 3,3
    • Remove the stitching on the heel side of the zipper.
    • The stitches on the heel side connect four layers of material: the lining, the zipper underlay, the zipper, and the outer leather.
    • Work between the leather and the zipper by pulling apart the leather and zipper and inserting the seam ripper into the gap.
  3. Boot Zipper Replacement: 步骤 3 中的图像 1,2 Boot Zipper Replacement: 步骤 3 中的图像 2,2
    • Remove the stitching on the toe side of the zipper.
    • The stitches on the toe side connect three layers of material: the lining, the zipper, and the outer leather.
    • Set aside the original zipper.
  4. Boot Zipper Replacement: 步骤 4 中的图像 1,1
    • Remove any leftover thread.
  5. Boot Zipper Replacement: 步骤 5 中的图像 1,2 Boot Zipper Replacement: 步骤 5 中的图像 2,2
    • Measure your zipper against the boot.
    • Use a pin to mark how long it should be.
  6. Boot Zipper Replacement: 步骤 6 中的图像 1,1
    • If your zipper is too long, trim it about an inch below your pin.
  7. Boot Zipper Replacement: 步骤 7 中的图像 1,2 Boot Zipper Replacement: 步骤 7 中的图像 2,2
    • Fold down the excess fabric at the top of the zipper twice to create a right angle.
  8. Boot Zipper Replacement: 步骤 8 中的图像 1,3 Boot Zipper Replacement: 步骤 8 中的图像 2,3 Boot Zipper Replacement: 步骤 8 中的图像 3,3
    • Stitch in place.
    • Use pliers if the fabric is too thick to push the needle through easily.
  9. Boot Zipper Replacement: 步骤 9 中的图像 1,2 Boot Zipper Replacement: 步骤 9 中的图像 2,2
    • Pin your new zipper to the outer leather on the heel side.
    • Be careful to put your pins through the existing holes in the leather to avoid damaging the leather further.
  10. Boot Zipper Replacement: 步骤 10 中的图像 1,1
    • Using a backstitch, sew the zipper to the leather along the inner row of stitching.
    • Be careful to put your needle through the existing holes in the leather to avoid damaging the leather further.
  11. Boot Zipper Replacement: 步骤 11 中的图像 1,2 Boot Zipper Replacement: 步骤 11 中的图像 2,2
    • Repeat steps 8 and 9 for the toe side of the zipper.
  12. Boot Zipper Replacement: 步骤 12 中的图像 1,2 Boot Zipper Replacement: 步骤 12 中的图像 2,2
    • Pin the lining to the zipper and leather on the toe side.
  13. Boot Zipper Replacement: 步骤 13 中的图像 1,2 Boot Zipper Replacement: 步骤 13 中的图像 2,2
    • Using a backstitch, sew the lining into place along the outer row of stitching.
  14. Boot Zipper Replacement: 步骤 14 中的图像 1,2 Boot Zipper Replacement: 步骤 14 中的图像 2,2
    • Pin the lining and zipper underlay to the zipper and outer leather on the heel side.
  15. Boot Zipper Replacement: 步骤 15 中的图像 1,1
    • Using a backstitch, sew the lining and zipper underlay into place along the outer row of stitching.
  16. Boot Zipper Replacement: 步骤 16 中的图像 1,2 Boot Zipper Replacement: 步骤 16 中的图像 2,2
    • This should be the final outcome after you repair the boot.
终点
Alex
于11/05/24注册
258 声望
撰写一个指南
团队
UC Davis, Team 4-2, Vidal-Chiesa Fall 2024 UC Davis, Team 4-2, Vidal-Chiesa Fall 2024 的会员
UCD-VIDAL-CHIESA-F24S4G2
3 名成员
创作了2篇指南
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 10
过去 7 天: 49
过去 30 天: 217
总计 1,494
