跳转到主内容
加入维修社区 - 创建账户
Boosted Mini Belt Replacement
你所需要的
  1. Boosted Mini Belt Replacement, Belt: 步骤 1 中的图像 1,2 Boosted Mini Belt Replacement, Belt: 步骤 1 中的图像 2,2
    • Unscrew the axle nut holding the wheel in place with your wrench on the side of the board where the belt has snapped/became worn.
  2. Boosted Mini Belt Replacement: 步骤 2 中的图像 1,2 Boosted Mini Belt Replacement: 步骤 2 中的图像 2,2
    • Take off the nut and the washer.
  3. Boosted Mini Belt Replacement: 步骤 3 中的图像 1,3 Boosted Mini Belt Replacement: 步骤 3 中的图像 2,3 Boosted Mini Belt Replacement: 步骤 3 中的图像 3,3
    • Use your allen wrench to remove the two black motor cap screws on the motor counter clockwise.
  4. Boosted Mini Belt Replacement: 步骤 4 中的图像 1,1
    • Remove the plastic motor cap.
  5. Boosted Mini Belt Replacement: 步骤 5 中的图像 1,3 Boosted Mini Belt Replacement: 步骤 5 中的图像 2,3 Boosted Mini Belt Replacement: 步骤 5 中的图像 3,3
    • Use your allen wrench to loosen the four motor screws on the motor by turning your tool ¼ turn left. The motor should be loose.
  6. Boosted Mini Belt Replacement: 步骤 6 中的图像 1,3 Boosted Mini Belt Replacement: 步骤 6 中的图像 2,3 Boosted Mini Belt Replacement: 步骤 6 中的图像 3,3
    • Remove the wheel and belt (if not snapped off already).
  7. Boosted Mini Belt Replacement: 步骤 7 中的图像 1,2 Boosted Mini Belt Replacement: 步骤 7 中的图像 2,2
    • Make sure the axle spacer and drive pulley washer are still in place on the axel.
  8. Boosted Mini Belt Replacement: 步骤 8 中的图像 1,3 Boosted Mini Belt Replacement: 步骤 8 中的图像 2,3 Boosted Mini Belt Replacement: 步骤 8 中的图像 3,3
    • Get your new Boosted belt and place it on the inner side drive pulley of the wheel.
  9. Boosted Mini Belt Replacement: 步骤 9 中的图像 1,2 Boosted Mini Belt Replacement: 步骤 9 中的图像 2,2
    • Place the wheel with its new belt inner side first on the axle, making sure the belt is securely back over the motor pulley.
  10. Boosted Mini Belt Replacement: 步骤 10 中的图像 1,1
    • To tighten the belt, create tension by putting your thumb on the wheel of the board and your fingers on the motor and pull the motor towards the motor driver until the belt is taught. There should be some flex in the belt after tightening.
  11. Boosted Mini Belt Replacement: 步骤 11 中的图像 1,2 Boosted Mini Belt Replacement: 步骤 11 中的图像 2,2
    • Using the allen wrench place the two screws furthest from the wheel first back in place and tighten, then tighten the closer two screws.
  12. Boosted Mini Belt Replacement: 步骤 12 中的图像 1,3 Boosted Mini Belt Replacement: 步骤 12 中的图像 2,3 Boosted Mini Belt Replacement: 步骤 12 中的图像 3,3
    • Place the axle washer and nut back on the axle.
    • Make sure that the axle washer is first, closest to the wheel, then the nut.
  13. Boosted Mini Belt Replacement: 步骤 13 中的图像 1,1
    • Use your wrench to turn the nut clockwise to tighten it.
  14. Boosted Mini Belt Replacement: 步骤 14 中的图像 1,1
    • Place the plastic motor cap on the motor.
  15. Boosted Mini Belt Replacement: 步骤 15 中的图像 1,3 Boosted Mini Belt Replacement: 步骤 15 中的图像 2,3 Boosted Mini Belt Replacement: 步骤 15 中的图像 3,3
    • Lastly, use the allen wrench to reinstall the two motor cap screws.
结论
If the belt on the other side of the skateboard also needs to be replaced, repeat steps 1-16.
另外一个人完成了本指南。
Juliana Renert
于02/02/24注册
241 声望
撰写一个指南
团队
UC Davis, Team 4-1, Andersen Winter 2024 UC Davis, Team 4-1, Andersen Winter 2024 的会员
UCD-ANDERSEN-W24S4G1
3 名成员
创作了1篇指南
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 2
过去 7 天: 5
过去 30 天: 9
总计 207
