跳转到主内容
Boosted Board 1st Generation Skateboard Bearings Replacement
你所需要的
  1. Boosted Board 1st Generation Skateboard Bearings Replacement, Rear Wheels: 步骤 1 中的图像 1,2 Boosted Board 1st Generation Skateboard Bearings Replacement, Rear Wheels: 步骤 1 中的图像 2,2
    • Loosen the two 16.74 mm motor mount hex nut screws with a 9/64" Allen wrench.
    • Do Not Remove the Screws.
  2. Boosted Board 1st Generation Skateboard Bearings Replacement: 步骤 2 中的图像 1,1
    • Compress the motor mount back towards the wheel.
    • While keeping the motor mount compressed, tighten one of the hex nuts that you loosened in the previous step.
    • The motor mounts are spring tensioned so it is necessary compress them to loosen the belts.
  3. Boosted Board 1st Generation Skateboard Bearings Replacement: 步骤 3 中的图像 1,2 Boosted Board 1st Generation Skateboard Bearings Replacement: 步骤 3 中的图像 2,2
    • Remove the axel nut with a 1/2" socket wrench
  4. Boosted Board 1st Generation Skateboard Bearings Replacement: 步骤 4 中的图像 1,3 Boosted Board 1st Generation Skateboard Bearings Replacement: 步骤 4 中的图像 2,3 Boosted Board 1st Generation Skateboard Bearings Replacement: 步骤 4 中的图像 3,3
    • Rotate and pull counterclockwise until the wheel comes off the axle completely.
    • The front washer will come off with the wheel.
    • Remove the back washer from the axle.
    • Replacing the wheel requires the bearings to be switched into the new wheel.
  5. Boosted Board 1st Generation Skateboard Bearings Replacement, Skateboard Bearings: 步骤 5 中的图像 1,2 Boosted Board 1st Generation Skateboard Bearings Replacement, Skateboard Bearings: 步骤 5 中的图像 2,2
    • Use one finger to pull out the pulley bearing.
    • A good technique is to go around in a circle and lift from underneath the bearing in a carving motion.
  6. Boosted Board 1st Generation Skateboard Bearings Replacement: 步骤 6 中的图像 1,3 Boosted Board 1st Generation Skateboard Bearings Replacement: 步骤 6 中的图像 2,3 Boosted Board 1st Generation Skateboard Bearings Replacement: 步骤 6 中的图像 3,3
    • Use an Allen wrench to apply pressure to the inside edge of the bearing until it pops out
  7. Boosted Board 1st Generation Skateboard Bearings Replacement: 步骤 7 中的图像 1,3 Boosted Board 1st Generation Skateboard Bearings Replacement: 步骤 7 中的图像 2,3 Boosted Board 1st Generation Skateboard Bearings Replacement: 步骤 7 中的图像 3,3
    • Replace bearing by dropping it in the center of the wheel and use a socket wrench to pop in back it place
  8. Boosted Board 1st Generation Skateboard Bearings Replacement: 步骤 8 中的图像 1,3 Boosted Board 1st Generation Skateboard Bearings Replacement: 步骤 8 中的图像 2,3 Boosted Board 1st Generation Skateboard Bearings Replacement: 步骤 8 中的图像 3,3
    • Slide the bearing spacer on to an Allen wrench
    • Align the Allen wrench in the center of the bearing and drop the spacer directly in the middle
    • Repeat Step 7 for placing the bearing in this side of the wheel.
结论
To reassemble your device, follow these directions in reverse order.
另外一个人完成了本指南。
Emily Imfeld
于10/06/16注册
532 声望
创作了4篇指南
团队
Cal Poly, Team 15-7, Livingston Fall 2016 Cal Poly, Team 15-7, Livingston Fall 2016 的会员
CPSU-LIVINGSTON-F16S15G7
4 名成员
创作了6篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 17
总计 762
