跳转到主内容
Bonaok Q37 Battery Replacement
你所需要的
  1. Bonaok Q37 Battery Replacement, Battery: 步骤 1 中的图像 1,1
    • Power down the microphone before proceeding to the next step.
  2. Bonaok Q37 Battery Replacement: 步骤 2 中的图像 1,2 Bonaok Q37 Battery Replacement: 步骤 2 中的图像 2,2
    • Hold the handle with your right hand and unscrew towards you.
    • Once the cover is unscrewed completely, remove the handle cover.
  3. Bonaok Q37 Battery Replacement: 步骤 3 中的图像 1,2 Bonaok Q37 Battery Replacement: 步骤 3 中的图像 2,2
    • Lift up the side edges of the "Caution" sticker to unseal the battery cover.
    • If the battery compartment cover is not sealed with a caution sticker, proceed to Step 4.
  4. Bonaok Q37 Battery Replacement: 步骤 4 中的图像 1,2 Bonaok Q37 Battery Replacement: 步骤 4 中的图像 2,2
    在这个步骤中使用的工具:
    • Use a pair of tweezers to push the cover towards the left.
    • Lift up the cover to remove it from the microphone.
  5. Bonaok Q37 Battery Replacement: 步骤 5 中的图像 1,3 Bonaok Q37 Battery Replacement: 步骤 5 中的图像 2,3 Bonaok Q37 Battery Replacement: 步骤 5 中的图像 3,3
    • Push the battery towards the left and lift it up from the (+) side.
    • Remove the battery from the compartment.
  6. Bonaok Q37 Battery Replacement: 步骤 6 中的图像 1,1
    • Insert a new battery into the compartment.
    • Make sure you insert the (-) end first, then push towards the left to make room for the whole battery to be pushed into the compartment.
  7. Bonaok Q37 Battery Replacement: 步骤 7 中的图像 1,3 Bonaok Q37 Battery Replacement: 步骤 7 中的图像 2,3 Bonaok Q37 Battery Replacement: 步骤 7 中的图像 3,3
    • Close the lid and seal back with the caution sticker.
    • Screw the handle back on by twisting it away from you.
  8. Bonaok Q37 Battery Replacement: 步骤 8 中的图像 1,1
    • Turn the power on and make sure the operating light is blue.
结论
Please charge the device completely before use.
Han Sol Lee
于01/17/22注册
157 声望
撰写一个指南
团队
6指南评论
What kind of battery?
Carmen Veguilla - 回复
Which type of battery? I looked on Amazon but can't find it. Must be age related problem, too old for new tech. 😊
Where can I buy replacement battery
Lee Fisher - 回复
NUMBER 18650 3.7volt lithium-ion rechargeable, available online everywhere BUT cannot ship with most carriers so delivery charge is expensive
William Row - 回复
What store sell 510 lithium battery for bonaok mic.
Tarryl Bradley - 回复
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 12
过去 30 天: 59
总计 2,997
