跳转到主内容
Bolide Technology Group Dual Alarm Clock Speaker Replacement
你所需要的
  1. Bolide Technology Group Dual Alarm Clock Speaker Replacement, Speaker: 步骤 1 中的图像 1,3 Bolide Technology Group Dual Alarm Clock Speaker Replacement, Speaker: 步骤 1 中的图像 2,3 Bolide Technology Group Dual Alarm Clock Speaker Replacement, Speaker: 步骤 1 中的图像 3,3
    • Slide the clear plastic case off of the speaker
  2. Bolide Technology Group Dual Alarm Clock Speaker Replacement: 步骤 2 中的图像 1,3 Bolide Technology Group Dual Alarm Clock Speaker Replacement: 步骤 2 中的图像 2,3 Bolide Technology Group Dual Alarm Clock Speaker Replacement: 步骤 2 中的图像 3,3
    • Remove the batteries on the bottom of the radio
    • Locate and remove the five screws on the bottom of the radio with a Philips Head Screwdriver.
    • Make sure to keep your screws together so you don't lose them.
  3. Bolide Technology Group Dual Alarm Clock Speaker Replacement: 步骤 3 中的图像 1,3 Bolide Technology Group Dual Alarm Clock Speaker Replacement: 步骤 3 中的图像 2,3 Bolide Technology Group Dual Alarm Clock Speaker Replacement: 步骤 3 中的图像 3,3
    • Grab your nylon pry tool and wedge it between the outer case and the top of the radio. Slowly pry open the top and remove it.
    • This may be more difficult to take off if the top hasn't been removed before, but it may be easier to turn the clock upside down for this step.
  4. Bolide Technology Group Dual Alarm Clock Speaker Replacement: 步骤 4 中的图像 1,2 Bolide Technology Group Dual Alarm Clock Speaker Replacement: 步骤 4 中的图像 2,2
    在这个步骤中使用的工具:
    Spudger
    $2.99
    购买
    • Using a black nylon spudger to carefully break the glue around the outside of the speaker so it can be dislodged.
  5. Bolide Technology Group Dual Alarm Clock Speaker Replacement: 步骤 5 中的图像 1,3 Bolide Technology Group Dual Alarm Clock Speaker Replacement: 步骤 5 中的图像 2,3 Bolide Technology Group Dual Alarm Clock Speaker Replacement: 步骤 5 中的图像 3,3
    在这个步骤中使用的工具:
    购买
    • Locate the speaker plug for the speaker you wish to remove and slightly tug on it until it becomes unplugged
    • This can also be done with a pair of tweezers if you find there isn't enough space.
  6. Bolide Technology Group Dual Alarm Clock Speaker Replacement: 步骤 6 中的图像 1,2 Bolide Technology Group Dual Alarm Clock Speaker Replacement: 步骤 6 中的图像 2,2
    • After the speaker cord is removed, pull the speaker straight up and out of the radio.
  7. Bolide Technology Group Dual Alarm Clock Speaker Replacement: 步骤 7 中的图像 1,2 Bolide Technology Group Dual Alarm Clock Speaker Replacement: 步骤 7 中的图像 2,2
    • Once the speaker is removed, the inside of the dual alarm clock should look identical to the photo shown.
结论
另外一个人完成了本指南。
Mercy Adeshola
于02/20/17注册
121 声望
撰写一个指南
团队
USF Tampa, Team 10-1, Remmell Spring 2017 USF Tampa, Team 10-1, Remmell Spring 2017 的会员
USFT-REMMELL-S17S10G1
4 名成员
创作了2篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 1
过去 30 天: 24
总计 679
